Old 06-22-2003, 07:50 PM   #1
Stainless
TH400 Kickdown switch
Hey all.... was wondering, did any of our trucks come with a TH400 tranny? If so.... where was the kickdown switch? On the gas pedal or carb?
I have a TH400 (out of an olds), but no it doesn't downshift. I found where a single wire plugs into the tranny, so I assume that is it. Is that just straight 12v to actuate it? Any info would be appreciated!!
~Sean
Stainless is offline   Reply With Quote
Old 06-22-2003, 08:04 PM   #2
RipMeyer
RipMeyer's Avatar
This is the one I used for my 69. It goes on the linkage at the carb.
TH400 Kickdown Switch
RipMeyer is offline   Reply With Quote
Old 06-22-2003, 08:47 PM   #3
Gee_Emm
http://67-72chevytrucks.com/vboard/s...threadid=57665
Gee_Emm is offline   Reply With Quote
Old 06-22-2003, 09:02 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Depends on what year your truck is. 69 & 70 have the switch on the carb as shown in the post linked to by Gee Emm. 71&72 have the switch mounted on the accelerator in the cab, those models use a cable instead of linkage. The latter is a better setup, IMO. I would consider converting if you have the older truck.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-22-2003, 09:24 PM   #5
Stainless
Awesome!! Thank you very much... Gee_Emm... you mentioned a two wire terminal.... do you know if it's just 12v in, and a standard pushbutton switch?
Thanks for all the info!!
~S
