Old 04-25-2013, 10:23 AM   #1
rollbig79
Tie rod replacement
So just wondering any ideas on how big a pain in the butt everyone would think it would be to replace tie rods on my 79 chevy K10. I have owned this truck for over a year and not sure how long it has been since they have been replaced...but the steering does a lot of walking...so I know they are shot. Would it just be smarter to take it to shop that has power tools and lifts.?
rollbig79 is offline   Reply With Quote
Old 04-25-2013, 10:29 AM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: Tie rod replacement
Pretty simple, actually. Inners, outers, or both? Also, check your pitman arm. Do yourself a favor and pick up a tie rod and pitman arm puller like this:
http://www.harborfreight.com/tie-rod...ller-1752.html
All you really need is a 13/16? socket and this tool.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-25-2013, 10:34 AM   #3
rollbig79
I would probably do both inner and outer....better safe then sorry. Ya I am sure I can rent that tool from the parts store.
Old 04-25-2013, 10:35 AM   #4
75chev4x4
75chev4x4's Avatar
Not bad at all to do just measure the threads of each side of the old before you take it apart so you can get the new ones close. Buy a good replacement tie rod like moog or you will be doing the job twice, I know. When u take the castle nuts off to break the rod end loose hit what it goes through with a hammer or u can use a pickle fork to seperate it. Thread your new ones in close tighten the jam nut and go get an alignment.
75chev4x4 is offline   Reply With Quote
Old 04-25-2013, 10:47 AM   #5
rollbig79
Thanks guys. I was worried about doing this because of frozen up parts, but seems like it will be pretty easy.
Old 04-25-2013, 10:56 AM   #6
75chev4x4
75chev4x4's Avatar
I would try and find a good shop to do your alignment, I alsways had problems with places like firestone. Found an old timer that sets it up just perfect and it drives great.
Old 04-25-2013, 11:10 AM   #7
Keith Seymore
Keith Seymore's Avatar
Just a point of clarification: On a K truck (which has a solid front axle) there will only be one tie rod, across the front from spindle to spindle.
There is also a fore/aft drag link, which connects the LH knuckle to the steering gear pitman arm.
Should be a pretty straighforward fix.
One more thought - once you have convinced yourself all the parts are in good shape have your alignment guy crank up the caster (like to 10 degrees). It will make a huge difference in your straight line stability and "on center" feel.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-25-2013, 11:24 AM   #8
rollbig79
Thanks a lot. I thought it would only be a straight front axle and would not be all that other noise...just wanted to cover my bases on ease. I will def take that recommendation on the alignment. I want this ole beast to drive straight when I let go of the wheel. lol.
Old 04-25-2013, 11:47 AM   #9
83GMCK2500
You mentioned it wandering, look over the rag joint at the steering box, when they wear out it can wander.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-25-2013, 01:53 PM   #10
rs74
rs74's Avatar
Tie rods usually come off pretty easy but I have had a few to where I had to use a torch. Had to heat them up before they would started to move. I always use anti-seize when putting parts like that back together.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
