Trans/drive shaft question
Getting ready to start my T5 swap this weekend. I have gathered all the parts. I'm mustering up the courage, but have one important question. I have not yet pulled the old transmission, a stock 3 speed/column shift. Does anyone know how many splines are on the output shaft? I'm obviously going to have to have the drive shaft cut down. I want to have all the parts ready so I don't have to go hunting for the right yoke at the last minute.... I will use the old one if it will work, but will have to figure out a solution if it's not going to work.
Thanks in advance, JJ |
![]() Join Date: Oct 2005
Re: Trans/drive shaft question
I'm not shure of the count but it will be different. You need a 68 up yoke. Practically any one will work except one from a TH400. You will need to get the trans. in to measure the drive shaft length.
and a few others
Lots of good info here, in case you hadn't seen it yet:
http://67-72chevytrucks.com/vboard/s...d.php?t=313954 Is this the method you're going with or the adapter plate method?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
should be a 10 spline
very common for those years
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#6 | |
Posted via Mobile Device |
I used a 92 V8 Camaro T5 in my Nova and used a TH350 yoke, it fit right in. This one had the electronic speedo but it used gears to spin the electronic sensor. BTW a speedo bullit from a TH350 fits perfectly in the hole so I could hook a cable to it.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
#8 | |
