1986 Suburban Specifications
I’m about to inherit a 1986 Suburban from my wife’s great-uncle Paul. Uncle Paul is still with us but at 91 he’s starting to get rid of some of his rides. He bought the Burb new in 1985 in the California bay area and used it to tow his boat around. He sold the boat three years ago so he really has no use for it. He knows that I’m a chevy guy, having two K5’s and he thought that I should have it for $1. Good news is it is a single owner California rig and I’m sure it is in awesome condition. The bad is it doesn’t run. I’m mechanical, I can fix it eventually….
This is what I know about it so far. 1986, ¾ ton, 4wd, 6.2L, TH400/NP208, buckets and middle bench, no third row seat, barn doors, two tone read and cream. One question I’ve been trying to get answered is if this level of Sub would have a full floating rear axle or if the Subs only had the 9.5” semi-floating axles. Trying to find the time to grab a trailer and drive the 600 miles to get it… any tips on what to look for would be appreciated. And the motor ran, just not for a long time, I’m guessing IP and possibley rotton fuel lines clogging up the filter? |
Re: 1986 Suburban Specifications
I have the same truck but an -82. I changed out the t-case though to np205.
It has a 9.5 semi float axle. Does the engine stall when it gets hot? And if so does it run again after you pour some water on the injecting pump? I never had one that had a malfunction pump like that though, but what happens is that when it gets hot the pump piston stops. Put some cold water on it and it runs again you know you need a replacement injection pump. Blocked fuel filter should be indicated by the warning light of restricted fuel filter. I would get it if I were you, not many 3/4 tons with a diesel around with one owner. |
Thanks for the tip on diagnosing the injector pump, I know my Chevy's but not the Detroit diesels!
There is no question this rig is coming home with me... Just a matter of when. Thanks! |
My '86 C20 Suburban has the 10.5" Full Floating rear end in it. It's also a factory severe duty towing package truck with a 454. I'm not certain if that affects the rear end choice, but some of the burbs definitely came with the full floating rear.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
#6 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Of all the suburbans i've looked at only one has ever had a full floater although i haven't looked at a whole lot of diesels but even the few i have only had a semi floater but unless your doing some hardcore off roading i dont think it will never be an issue, or at least for me it never was
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
