04-25-2013, 06:31 PM | #1 |
Ford Steelies for '69 Chevy C20?
Not what I prefer, but would they work? My thanks in advance.
04-25-2013, 07:20 PM | #2 |
Re: Ford Steelies for '69 Chevy C20?
Those wheels have a metric bolt pattern and from what I know will not work. I could be wrong.
04-25-2013, 07:38 PM | #3 |
I'm running ford steelies on mine. They are 8 lug Accuride. They are a different style, but I don't see why those wouldn't work. Have you tried bolting one on yet to see?
Posted via Mobile Device |
04-25-2013, 08:00 PM | #4 |
The earlier Ford wheels are the same bolt pattern and will accept hubcaps, I am pretty certain the wheel pictured is late model and the bolt pattern is slightly different. Some time in the late '90's Ford went to a metric bolt pattern and those wheels don't interchange with other trucks.
04-25-2013, 08:02 PM | #5 | |
04-25-2013, 08:24 PM | #6 |
I read a post under 'Questions about steelies' where member Special-K says it has to have stamped 'Accuride' on the rim next to the size to be SAE. But that was for the style rim I like, possibly an older style from Ford. Wonder if the 4.5 back spacing is happening with these, too. Looked at many pics that members have posted and I've not seen these on any yet. Maybe there's a reason.
04-25-2013, 08:37 PM | #7 | |
04-25-2013, 08:54 PM | #8 |
These are what you seek Grasshopper...
MusicMan70 1961 GMC Suburban |
04-25-2013, 08:58 PM | #9 |
04-25-2013, 09:00 PM | #10 |
That I do not know.
04-25-2013, 10:03 PM | #11 |
The Niner
Those won't work. That's an 8 x 170mm bolt pattern.
You need an 8 x 6.5" bolt pattern like what Musicman70 showed in Post #8.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
04-26-2013, 12:08 AM | #12 |
Proprietor of Dale's Corner
those newer ones take metric lugnut with a washer not a tapered nut
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-11-2013, 12:18 PM | #13 |
These are off a 2001 E350 Van, 8 lug 16" good to go?
08-11-2013, 10:53 PM | #14 |
From what I understand,the Van wheels stayed SAE. BUT...at some point they stopped using hubcaps and we3nt with only wheelcovers. Once they did that the wheels changed and no longer have the "nubs". I've wondered about those styled Ford truck wheels before,but figured they went into us when the '96 Super Duty design came out,which is when the old-style wheels went metric. It is odd that those are Accurides. I guess Accuride started supplying styled steel wheels when Ford went metric and someone else started supplying the old-style wheels.
08-11-2013, 10:59 PM | #15 |
What is a good and easy to find alternative for split 6 lug steelies with nubs for caps?
08-11-2013, 11:05 PM | #16 |
I have a radical idea!
Split 6 lug steelies? I've never seen 6 lug split wheels.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-12-2013, 12:17 AM | #17 |
Weren't they originally 2 piece wheels? That is what I meant
08-12-2013, 07:59 AM | #18 |
2pc is another name for split rim...or visa-versa. I'm still not sure what you need to know,though. What are you looking to do? There are endless 6-lug wheel choices available.
08-12-2013, 07:07 PM | #19 |
Just an alternative for finding era correct steelies. So something newer, 6 lug, hub cap nubs and easy to find
08-13-2013, 10:48 AM | #20 |
They were used on 4wd 1/2t pickups,Suburbans,& K/5s through '91. My '85 Jimmy had them on it before I put 8-lug axles under it.
08-13-2013, 12:55 PM | #21 |
Watch out for your cornhole !
Original poster, those are metric pattern Ford wheels. They won't work on your truck.
I believe you're gonna find that your original wheels are one piece. I've never seen a two piece 6 lug wheel on one of these trucks. If you could post a picture, we could tell for sure. Posted via Mobile Device |
08-13-2013, 09:28 PM | #22 | |
08-13-2013, 09:44 PM | #23 |
Dakattack....
If you're still running drum brakes in the front, you can use a set of stock truck wheels which should be very easy to find. Pretty much any 6 lug guy that converts to disc brakes is gonna have some up for grabs cheap. It's a shame you're not close by, I throw a lot of them away when I build trucks, or do something like build grinder stands out of them. Posted via Mobile Device |
