04-25-2013, 08:40 PM | #1 |
High hump?
What is the high hump for ?
Posted via Mobile Device |
04-25-2013, 09:03 PM | #2 |
Re: High hump?
High humps are usually found on 4x4s and big block/turbo 400 2wds, but not always!
If you have no carpet, or it is removed, there is a removable, bolt in cover on the high humps. Clear as mud? |
04-25-2013, 09:33 PM | #3 |
Re: High hump?
High humps came on 4x4's and 4-speed manual trucks. I believe on the big block TH400 trucks too, usually. Some boardmembers have the TH400 with a low hump.
The low hump is part of the floor pan, the high hump is bolted in. You can easily cut the low hump out and bolt a high hump in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-25-2013, 09:36 PM | #4 |
Re: High hump?
My 72 1/2 ton 2wd 400/TH400 has a high hump.
Picture attached. |
04-26-2013, 06:36 AM | #5 |
1969 Custom 30 wrecker
Re: High hump?
Don't forget trucks with the 4 speed. (probably the main reason they had high humps!) Both my Cheyenne 20 and Custom 30 have it.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-26-2013, 09:37 AM | #6 |
Re: High hump?
When looking at trucks, I only considered high-hump trucks so there is plenty of room for the Tremec 5-speed tranny that will reside there before long.
04-26-2013, 09:47 AM | #7 |
Re: High hump?
Be aware that there are two types of covers - a 6 cylinder, and an 8 cylinder. The placement of the opening for the shifter is a little different (in the manual trucks). I'm not sure if the high hump in the autos had any opening on them at all.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-26-2013, 10:16 AM | #8 | |
Re: High hump?
Any pics of the differences? My 66 has a low hump but I noticed that the shifter hole isn't actually centered...
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
04-26-2013, 02:53 PM | #9 | |
Re: High hump?
04-26-2013, 03:54 PM | #10 | |
Re: High hump?
The 4-speed V-8 shifter hole is up forward and pretty much at the upward flaired section the I-6 location is 3.8" further back and conpletely on the flat section. There are illustrations in the assembly manual if you dig around.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-26-2013, 04:24 PM | #11 |
TuTone Silverado
Re: High hump?
I think this is for a V8 4X4. Got it as a spare part with the truck I bought.
13 Corvette GS vert 13 Ram Laramie Longhorn 11 Wrangler Sahara unlimited 08 300 76 El Camino 67 Bel Air sedan 63 Corvette SWC 08 HD Road King Classic 68 HD Golf car |
04-26-2013, 04:53 PM | #12 |
Re: High hump?
Pretty sure that is a V-8 4x2 4-speed cover. The V-8 4x4 is aft the same as the I-6. My mistake earlier.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-26-2013 at 05:05 PM. |
04-26-2013, 05:25 PM | #13 |
Re: High hump?
This might help. Also shows the double bend vs single bend levers.
04-26-2013, 06:30 PM | #14 |
Re: High hump?
04-27-2013, 08:45 AM | #15 |
Re: High hump?
it LOOKS like a high hump to me.
04-27-2013, 01:23 PM | #16 |
Re: High hump?
04-28-2013, 11:13 AM | #17 |
Re: High hump?
Based on those pics, I change my vote to low hump.
