Old 04-25-2013, 10:20 PM   #1
nvrdone
Switch location problem
I'm installing my power window kit. The motors went in great. The switches ... That's a different problem.
I need to know how to mount the switches and where to route the wires. If I cut a hole in the interior door sheet metal and run the wires inside the door how do I connect the switch when the switch is mounted to the upholstery panel ?
Or should I run the wires between the sheet metal and the upholstery panel ?
This is in a 1949 Chevy 3100. Pictures or diagrams would be great.
Thanks for the help
nvrdone is offline   Reply With Quote
Old 04-26-2013, 12:17 PM   #2
_Ogre
_Ogre's Avatar
Re: Switch location problem
Originally Posted by nvrdone View Post
pictures or diagrams would be great.
shop air compressor timer
Old 04-26-2013, 11:14 PM   #3
nvrdone
Old 04-26-2013, 11:15 PM   #4
nvrdone
Then I guess this thread is worthless. I'm technically challenged when it comes to posting pictures.
Old 04-27-2013, 12:34 AM   #5
Daze57
Daze57's Avatar
i am sorry sir - this thread is not worthless -there are plenty of good people on this forum here to help - sometimes it takes a day or too b4 you get a response ! just give us a chance
i am sure someone can help you out . As far as pictures - we just like to see what exackly you are up against - it gives us a better perspective of your situation .
if you can write on this forum - i know you can post pictures . it isnt hard and it helps us out -- to help you solve your problem and make it work .
just my 02 centavos worth
Daze57 is offline   Reply With Quote
Old 04-27-2013, 12:28 PM   #6
parkwood
parkwood's Avatar
since i don't know what kind of switch's you are using i'll show you what i did.. i used the kind of switch that you use a stock door handle on.. i did have to cut the door to let the switch sit back a little so there wouldn't be a big bump on the door panel when it was installed.. i did run the wires on the inside of the door but you have to hold them down someway so they will not get cut by the window moving up and down..
Now not knowing how your's look or fit i can't tell you if you need to cut the door or not.. what was the name of the window kit you used and that may help someone know about this than me.. most after market kits come with the black rocker type switch's..
parkwood is offline   Reply With Quote
Old 04-27-2013, 01:40 PM   #7
nvrdone
Ok sorry for the lack of info. It's a specialty window kit with their gm style lever switches
I'm trying to figure out if its easier to run the wires between the sheet metal face of the door and the upholstery panel or inside the door. I've seen some rigs on here that have the same style switches
Old 04-27-2013, 08:41 PM   #8
G&R's57GMC
G&R's57GMC's Avatar
Nothing sez the switches have to mount on the doors.
You could mount them in the center of the dash.
That would allow you to operate the passenger window and visa versa, and lessen the wiring.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 04-27-2013, 09:08 PM   #9
nvrdone
I thought about that. The problem is I couldn't find a toggle switch that was momentary on up and down. If any one has ideas I'm open.
Old 04-27-2013, 09:41 PM   #10
G&R's57GMC
G&R's57GMC's Avatar
I was thinking use the double GM switch you have and cut a hole in the dash for it.
Glen & Jane's Rides
Old 04-30-2013, 08:57 AM   #11
nvrdone
Newfisher - can you chime in on this?
Old 04-30-2013, 10:51 AM   #12
_Ogre
_Ogre's Avatar
a regular toggle switch won't work, even a momentary dpdt doesn't have the functions you need.
window switches have a reversing function built in them, 3 wires in, 2 out
if you have 2 switches they mount in a console, so you can roll the passenger window up/down
3 are required for door mounting, 2 in the drivers door and one in the pass door
with 3 switches the wiring gets a little more complicated especialy getting all the wires in the door looms
here is a link to specialties wiring diagram for 2 switches
i mounted truk's switches in a console
Old 04-30-2013, 11:28 AM   #13
buggy5872
buggy5872's Avatar
Look aroud on the internet....there are several companies making switch kits. I do not remember what the company was that I used in Big Berhta. I have a 4 switch pod mounted in the center console. The rear doors do have a switch on each so I can control them or the person in the back can.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 04-30-2013, 10:18 PM   #14
nvrdone
I've got the switch kit from specialty power windows. It has two switches for the drivers door and one for the passenger door plus all the wire.
If I mount the switches to the finish upholstery panel ithe back of the switch with the plug fastened on does not clear the interior sheet metal panel on the door. If I mount the switch to the sheet metal how do I access the switch thru the upolstry panel?
If I mount the switch to the upholstery panel and route the wires up from the motor inside the door there is no way to plug into the back of the switch and still mount the upolstry panel.
I've seen pictures on here of these switches mounted on an upolstry panel so someone has figured out how to do it.
Please help.
Old 05-02-2013, 12:00 PM   #15
_Ogre
_Ogre's Avatar
usually the switches are mounted in the panel and the wiring is long enough to plug/unplug once you undo the panel
hiding wires behind a stock trim panel may make it hard to run wires
you could look at making an arm rest to mount them in
Old 05-03-2013, 12:31 AM   #16
nvrdone
Ok maybe I'm just not seeing the big picture here. I mount the switch to the upolstry panel. Got that. Then do I cut a big hole in the door panel so the plug has a space to fit into and run the wires down inside the door? Or do I route the wires down between the upolstry and the the door skin ? It seems like if I run the wires up inside the door and plug in the switch I won't be able to have enough wire length to remove the upolstry panel when I need to.
