350 cid timming
I had some problems, been away for awhile, I'm glad to be back.
I'm sure that this has been covered numerous times but: Timing my 350 Pretty much stock engine that I built about 15 years ago, has no miles on it. It has an TRW RV cam (what ever that is) I just got my cameo on the road (Photos to follow) Right now I have the timing set at 8 degrees initial, hook it up to intake and it goes to 24. Total is about 35. Question: Ported or manifold vacuum and what initial and total timing would you suggest. It is just a cruiser. Thank you Ed |
Re: 350 cid timming
That is a v v nice truck sir !!!!!!
Posted via Mobile Device |
Re: 350 cid timming
set your timing without using vacuum advance...
set your total... dont really worry about initial ( i mean getting 34-36 etc total is a lot more important than 6-12 initial), plus in your van advance when you're done.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
