Old 04-25-2013, 11:31 PM   #1
c10 custom
mustang 2 coil springs
hi guys i have a 1950 chev truck and i have a mustang front end and was wondering if i could get smaller springs to put on instead of the springs that i have now anybody with any information would be great
c10 custom is offline   Reply With Quote
Old 04-26-2013, 12:17 AM   #2
parkwood
parkwood's Avatar
Re: mustang 2 coil springs
when you say smaller do you mean shorter??
parkwood is offline   Reply With Quote
Old 04-26-2013, 08:03 AM   #3
Rude Dude
Rude Dude's Avatar
If your using a Mustang II you maybe want to run V6 coil springs, if you want to cut one coil off it will drop it about 2 inches. I am using V8 springs with one coil cut with drop spindles and it sits pretty low but my truck is a 1956 Chevy and weighs a little more than a 50. If your running 4cyl springs maybe too light for your application. Also run it for a while before cutting the springs it will settle an inch or so, the after being on the road cut coil spring with a cut off wheel not a torch. The heat from torch causes the spring to lose tensile strentgh and it will start to sag.
Rude Dude is offline   Reply With Quote
Old 04-26-2013, 11:58 AM   #4
_Ogre
_Ogre's Avatar
why do you need smaller springs?
a little more detail will help us help you
the short answer is yes, you can put a screen door spring in there if you want
it won't hold your truck, but yes you can do it if you want
shop air compressor timer
Old 04-26-2013, 11:12 PM   #5
c10 custom
i wanted a smaller spring its a mustang 2 front end with 2 inch drop spindles on a 1950 chev truck would any one have pictures of there truck lowered with spring cut
