70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Shock Absorber Question
I am going be swapping the rear end in my truck and am wondering if I should change the shocks at the same time. I've had the truck ( 72 Chev longbox )since 2001 and the only thing wrong with the shocks that are on it now are the squished rubber bushings. The shocks dont leak and the truck sits as it should. Is it practical to put the same shocks back on the truck?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: May 2011
Re: Shock Absorber Question
I have seen shock companies state that shocks need to be change every 50K miles, but I would check them first. If you push the vehicle down on one of its corners and let go the suspension should travel up and and down far enough stop at ride height. If the corner you push rebounds up and back down past ride height without a positive stop it is time for new shocks.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
#3 | |
If you really want to you could buy polly replacement bushings for a few dollars, but as long as the mounts are in the same locations there is no need to get new ones.
