Lokar column linkage.
Can anyone tell me the correct part number for the Lokar column linkage to connect the stock column to a 700r4. Im going to order one not sure if the correct one. Thanks
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
Re: Lokar column linkage.
Here is what Im looking at http://www.lokar.com/product-pgs/col...inkage-pn.html not sure which one will work.
![]() Join Date: Apr 2005
I'm pretty sure that's the one I'm using. (EDIT: ACA 1800)
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-26-2013 at 12:01 PM. |
Im guessing this will work P/N. ACA-1804
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I recommend the cable linkage if you have any kind of thumpy cam at all. I used the hard linkage, and with my rowdy cam, the shifter rattles all the time when in gear.
Good point!
#8 | |
The LOKAR ACA-1804 you're considering is what I'd recommend.
Ok Thanks just wondering if there were other brands that were comparable. This will work.
Just put my order with Amazon thanks guys.
