Old 04-26-2013, 10:45 AM   #1
Reyals Bemus
Reassembling tilt column, upper nut preload?
Hey guys,
I'm reassembling a '71 auto tilt column. I've got pretty much everything figured out, except I'm not sure how tight I should make the nut that cinches up the upper bearings. Is there a spec? Or do I just tighten it until there is no play in the shaft? Then another turn maybe or something? Really don't know.
Please let me know.
Thanks,
Matt
Reyals Bemus is offline   Reply With Quote
Old 04-27-2013, 11:13 AM   #2
Reyals Bemus
Re: Reassembling tilt column, upper nut preload?
Anybody?
Old 04-27-2013, 12:04 PM   #3
Daaaanz67
I think I went with taking out all play and 1/8 more.
Daaaanz67 is offline   Reply With Quote
Old 04-28-2013, 12:43 AM   #4
Reyals Bemus
Thanks man. I'll try that and see how it feels.
Old 04-28-2013, 02:07 AM   #5
SS Tim
SS Tim's Avatar
Torque to achieve 15 inch ounces of rotational effort moving the steering shaft. 71 factory chassis service manual 9-16.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 04-28-2013, 11:16 AM   #6
Reyals Bemus
Bam! Thanks so much Tim. So it's not unlike setting up rear end pinion bearing preload.
