Old 04-26-2013, 11:30 AM   #1
JCampbell
Pulsing/Surging Cruise Control
Cruise control pulses, or surges up and down when engaged. Sometimes it smooths out, other times not. '88 TBI 350.
Any ideas?
JCampbell is offline   Reply With Quote
Old 04-26-2013, 04:10 PM   #2
cleansquare
Re: Pulsing/Surging Cruise Control
Mine does it too. No idea. I put a new vaccum pod thingy on but no bueno
cleansquare is offline   Reply With Quote
Old 04-26-2013, 04:19 PM   #3
JCampbell
I'm going to pull a vacuum on the cruise "solenoid" this weekend and see if it holds. Might just be a leaky vacuum line somewhere.
Old 04-26-2013, 04:32 PM   #4
SCOTI
SCOTI's Avatar
This would be my guess... not holding vacuum @ some point in the system.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-26-2013, 07:24 PM   #5
tucsonjwt
Mine cuts out on the downhill travel, will not hold below 45 mph. I replaced all the vacuum lines, actuator, brake switch, everything but the control lever on the column (1983 model year only type). That switch/lever was not available until recently, and it is too much to warrant replacement. There is a circuit board in a red plastic box under the dash, but that has to be sent into the aftermarket manufacturer and they are supposed to be able to repair it.
Converting to electric cruise I think makes more economic sense - vacuum is an unreliable method IMHO.
tucsonjwt is offline   Reply With Quote
