HO52 to 14 bolt
First time post here!! I have a 1970 chevy c20 2wd that is currently in frame off resto status haha started as a motor build. well in my search for parts for my h052 i come back with almost no parts, and the parts that are available are way over priced. currently the rearend is open, and im looking for a locker. Ive looked into converting to a 14 bolt, then i can have disk brakes, A locker, and have more parts and gear ratio availability. what is involved in swapping these rearends? im figuring i will need a driveshaft built, new brake lines, and relocate the sway bar mount. Any suggestions from anyone? there is the jefferson swap meet coming up this weekend and i will be on the search for a 14 bolt, what would i need to look for or avoid? this truck is also coil spring rear
Re: HO52 to 14 bolt
Might want to look into just bolting in a Dana 60 from a big block coil spring truck. While a 14 can be adapted the panhard rod is more than just a stabilizer as it locates the rear left to right.
On the disc brakes, the kits I'm aware of use car calipers and a car rated mechanical park brake if at all. While these are useable in a pet truck they have no place in a loaded C20 IMHO.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: HO52 to 14 bolt
would anything else need to be changed? this truck although is a c20 wont be pulling much of a load, maybe a small trailer here and there. on a dana 60 would the panhard bar bracket already be welded to the axle or would i have to weld mine on?
Re: HO52 to 14 bolt
It was the stock axle with big blocks on coil spring trucks. So the saddles, panhard and shock mounts is all there. If you look through the power train charts it is listed as a dana 5500 axle. Now there were both coil and leaf versions as well. The coils only came in 3.54 IIRC. It will be a bolt on. Grab the full park brake cable set to just in case if you can. Driveshaft I am not sure about at this point.
Renew the drum brakes and call it done. If you need a posi they are out there or just drop in a lunchbox locker. Check out my power team thread linked down in my signature.
#5 | ||
"I ain't nobody, dork."
Re: HO52 to 14 bolt
There are 3 different 14 bolts. The huge 11.5" ring Full and semi floaters, and then the 9.5" lighter duty 14 bolts that were in 1/2 ton trucks from the late 80's onward. They all had drum brakes as far as I know.
You would need to swap perches, and set up a panhard rod. Not to mention they will probably be wider than what you want. So you might have to shorten the tubes and get shorter axles as well. Lockers for 14 bolts of any kind are very pricey. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Re: HO52 to 14 bolt
thanks for the help guys! hopefully i can find one at the swap meet
Re: HO52 to 14 bolt
http://67-72chevytrucks.com/vboard/s...d.php?t=495913
Captainfab in the 60-66 section has the spring perches. The 73-87 14 bolts will move your rear wheels out about a 1 1/2" but if you do frontend swap they will be even as that moves your front wheels out also. Some of the later models are HD 11.5" ring gear, the early to late 70's full floater are the 10.5", and the semi-float are the 9.5". No reason to get the semi-float unless you don't like pulling hubs to get your drums off. The 88-98s are about the same width as the H052. The 99? to 2006 are the same width I think as the 73-87 but are disc brake. You can get a adjustable panhard bar from Early Classic Ent, CP, and others.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
Re: HO52 to 14 bolt
front end swap not really an option at this point, ive replaced pretty much everything up there already with new parts and dont want to buy them again. does anyone know where i can find a detroit locker for the ho52 that wont cost me a million bucks? what would you guys do? 14 bolt or dana 60? the dana 60 sounds easier to swap but its a pretty narrowed search as to what i can buy
Re: HO52 to 14 bolt
Keep your eyes open for a Dana 60 from a big block C20 pickup or C20 suburban. 70 down ft drum or 71 up ft disc should address and track differences. Need to check that myself. A NoSpin is going to be expensive. They pop up from time to time on the board and ebay. Krazy Ray is going to have a 4.57 NoSpin drop out listing later might want to check his current classifieds on that time line. Just remember your current axle is likely a 4.10 and a 3.54 D60 would be like O/D all the time. A 14 bolt is going to be research and work. In the end how much money and time do you want to spend.
Re: HO52 to 14 bolt
This is something to keep handy if you are looking at D60 axles.
Moderator
![]() Join Date: May 2007
Re: HO52 to 14 bolt
I don't know about where you live, but here Dana 60's are plentiful on 67-72 trucks at the pick n pulls, might even get lucky and find one that has a posi.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#12 | |
Re: HO52 to 14 bolt
C20pickup do you know how to find the B.O.M. number?
#13 |
Re: HO52 to 14 bolt
#14 | |
Re: HO52 to 14 bolt
#15 |
Re: HO52 to 14 bolt
The 14 bolt Detroit locker and disc brake swap kits work on the HO52's. The biggest thing you gain is more gear ratios.
1939 Chevy 1/2 Ton (30 year long father/son project) 1997 Jeep TJ on 1 tons 2011 Cummins 1972 GMC Jimmy |
#16 |
Re: HO52 to 14 bolt
#17 | |
Re: HO52 to 14 bolt
B.O.M. Is the unique build ID number telling you pretty much everything. Check out the chart picture for detail and locations.
If you find another drop out like Ray's 4.57 the NoSpin can be transfered over without having to reset the gears like a Dana or a 14 bolt would require for several of the carrier locker options. The detroit locker from a 14 bolt can be installed in a HO52 or HO72 but the side gear splines are different and require matching modified 14 bolt axles be used.
#18 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: HO52 to 14 bolt
My HO52 was recently rebuilt along with the drum brakes. Parts were not an issue and I had a locker added that I purchased from the parts board. I thought about an axle swap for my K20 and am glad I kept the HO52. I'd keep the H052 and post a WTB add on the parts board for a locker.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#19 |
Re: HO52 to 14 bolt
The detroit locker from a 14 bolt can be installed in a HO52 or HO72 but the side gear splines are different and require matching modified 14 bolt axles be used.[/QUOTE]
by modified you mean? ive heard of guys running 14 bolt axle shafts but they must be shortened, is this what you mean by modified? is there any other mods required to make a 14 bolt locker fit? will i need to use the 14 bolt r&P or can i use my eaton? if installing a 14 bolt locker requires little modifications that will be the route i go |
#20 | |
Re: HO52 to 14 bolt
#21 | |
Re: HO52 to 14 bolt
#22 |
Re: HO52 to 14 bolt
Welcome from Oak Creek. Did the same thing last year. Couple of pictures for you. Mine had coils, but overall the same concept with the disks. Still need to work out the parking brake, but if you have an automatic then no worries. If you know anyone that needs an HO with 4:56 and drums got one laying around. If you ever find your way up here give me a shout. Interestingly enough i was able to use my original driveshaft.
#23 | ||
Re: HO52 to 14 bolt
There is actually very little difference between a HO52/72 NoSpin and a 14 bolt Detriot Locker. They both replace the case internals only. Nothing else is interchangable as far as R&P related items. Don't think you are going to find enough of a price advantage to cover the axles. Quote:
Nice looking installation. But I cannot disagree more, automatics need a park brake. That "park" pawl is not a substitute in fact the heavy C30 don't have a park position at all. A good park brake is a must. How well do yours hold under a load?
#24 | |
Re: HO52 to 14 bolt
#25 |
Re: HO52 to 14 bolt
http://www.ebay.com/itm/HO72-HO52-CH...f01b90&vxp=mtr
what do you guys think about this locker? should i buy the used eaton locker or go for a new 14 bolt locker? are all the parts in these pictures? (not really an expert on rearends or lockers) |
