Old 04-26-2013, 01:37 PM   #1
Sloan66
Sway Bar Bushing?
I found teh FAQ thread, but here is my question. The bar I purchased off a 78 suburban, the brackets are taller where it attaches to the a-arm. I do not see any different bushings for fram vs. a-arm. The bracket is easily 1/2 inch taller than the frame bushing bracket.
Sloan66 is offline   Reply With Quote
Old 04-26-2013, 06:46 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: Sway Bar Bushing?
I ran into the same thing. I just went back to the junk yard and got a second set of the taller brackets. The bolt holes have the same spacing. Have not seen any replacement bushings for the smaller ones.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
