Old 04-26-2013, 04:14 PM   #1
crossfire84
crossfire84's Avatar
what is this?
I could use some help here, what is this box on the last support of the AD box? One on each side and what are they for? Thanks.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-26-2013, 04:49 PM   #2
S10Fan
Old Heap Driver
Re: what is this?
Frame mount.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-26-2013, 05:18 PM   #3
crossfire84
Re: what is this?
Originally Posted by S10Fan View Post
Frame mount.
My frame is nowhere there that thing.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-26-2013, 05:22 PM   #4
Bubba54
Re: what is this?
Yep, it mounts the bed to the frame. When installing the bed wood, there will be a board thats right over each one of the boxes and a bolt go through to the frame. Good luck with the install.
Bubba54 is offline   Reply With Quote
Old 04-26-2013, 06:27 PM   #5
crossfire84
Re: what is this?
The frame does not go under these. there about 6" away.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-26-2013, 06:47 PM   #6
Bubba54
Re: what is this?
I know there are different rear sills for different years. There is also a difference between 1/2 and 3/4 ton sills. Is your truck a 3/4 ton ?
Old 04-26-2013, 07:05 PM   #7
S10Fan
Old Heap Driver
Re: what is this?
In this picture from LMC you can see the sill boxes and pads as they mount to the bed. Contact the seller and let them know the issue. I have 2 stepsides, both mount to the frame via the boxes on the cross sill.
Bryan
Old 04-26-2013, 07:25 PM   #8
crossfire84
Re: what is this?
so i could cut these off and weld them on just above the frame, sounds do-able.
the frame is a 3600, the box is for a 3100
thanks for the info everyone.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-26-2013, 07:28 PM   #9
G&R's57GMC
G&R's57GMC's Avatar
Re: what is this?
What year is your AD ?
The '47-'53 AD's have a splayed (wider at the rear) Chassis.
The '54-'59 AD & TF use a parallel Chassis.
If you bed is centered over the Chassis then I'd say you have a Parallel Chassis.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 04-26-2013, 07:31 PM   #10
crossfire84
Re: what is this?
the title says 50 but the frame is parallel.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-26-2013, 07:40 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
Re: what is this?
AS I was posting You posted that its a 3600. That would make it parallel and a early Chassis.
My Post was assuming a 1/2 ton chassis.
Glen & Jane's Rides
Old 04-26-2013, 07:41 PM   #12
Bubba54
Re: what is this?
If the bed fits otherwise, i dont think there would be a problem relocating the mounts.
Old 04-26-2013, 07:47 PM   #13
G&R's57GMC
G&R's57GMC's Avatar
Re: what is this?
Just for grins decode your chassis number in the LMC catalog VIN ID section.
That will help you with IDing just what you have. A lot can happen in 60 years to these old trucks.
Glen & Jane's Rides
Old 04-26-2013, 07:51 PM   #14
crossfire84
Re: what is this?
good idea, thanks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-26-2013, 10:48 PM   #15
mknittle
mknittle's Avatar
Re: what is this?
I just looked at a 1/2 and3/4 ton sills your frame looks to be 3/4 ton and your sill is 1/2ton 47-53. I would just move the mounts like you said. the sills are the same other than that.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-27-2013, 09:34 AM   #16
crossfire84
Re: what is this?
thanks, will do.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 05-11-2013, 01:59 PM   #17
crossfire84
Re: what is this?
Problem solved, made new mounts.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 05-12-2013, 08:54 AM   #18
Bubba54
Re: what is this?
Looks good. Nice way to hide the mounting bolts.
Old 05-12-2013, 09:29 AM   #19
crossfire84
Re: what is this?
thanks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 05-12-2013, 10:47 AM   #20
S10Fan
Old Heap Driver
Re: what is this?
Looks Great!
Bryan
Old 05-13-2013, 07:31 PM   #21
crossfire84
Re: what is this?
Looks Great!
thanks.
LIL ERV the 50-3600
C4 rear
Porter built a arms
