Old 06-22-2003, 10:18 PM   #1
Power Trip
Got Caddy?
Power Trip's Avatar
Question '77 leaf rear into a '69 coil rear??????
Hello I have been trying to swap my truck over to the popular 5 0n 5 lbot pattern. I have already put 5 lug disc on the front now time for the rear. The question is I have a '77 rearend from my brothers truck but its leaf. How hard would it be to cut the mounts off of mine and weld them onto the new rear. If that wont work what are some other ideas that you have. By the way my wallets on a diet and I have an excelent welder on hand. Thanks in advance for your help Jim
1969 c-10 swb fleetside with dreams
of a caddy 500 Bagged shaved and rollin' on 18's
Future bumper sticker.
Looks like a chevy, runs like a caddy!
Power Trip is offline   Reply With Quote
Old 06-23-2003, 10:40 AM   #2
rambler
MOVE OVER
rambler's Avatar
I've asked this question before in the past, From what I learned it should work, but you have to make sure everything is lined up correctly. I'm needing another rear end for my 72, and thought about the same thing, but paying a welder I can get a used 72 coil from a couple of guys in KC that part out our year of trucks,, I just missed a 72 posi.. (dang, still mad about that), $$$ is always the issue as well..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-23-2003, 11:13 AM   #3
tom hand
CCRider
tom hand's Avatar
There is a kit just for this. I comes with correct mounts and an extra long tracking bar that you need because you have to put the mount on the axle tube. You can find a pic of it in the Chevy Duty catilog
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-23-2003, 05:51 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some one was saying (please don't quote me on this) that you can slide the axles into your 69 rear end, and use the drums off the donor...
Is that right?
I know you can use the axles, but the drums will need to be a bit wider to make up the differance.
Old 06-23-2003, 07:10 PM   #5
crazy longhorn
Fabricate till you "puke"
The 70 diff should be a direct swap for the 71 up axles, but the 69 diff will be a little narrower. i have heard of swapping the longer axles in the narrow diff, & using the wider drums to make up the difference........but I wouldnt try it(I am a picky SOB!). You can get NEW Moser axles with studs, & shipped for about $260 crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-23-2003, 11:20 PM   #6
Power Trip
Got Caddy?
Power Trip's Avatar
well longhorn if i could do that it would be great. right now i'm not so picky i have a 3.08 rear in there now and that would go great with my motor.So just swap axles huh? Sounds good.
Tom thanks for pointingthat out i did not see it that still aint a bad deal if theaxle swap dont work.
thanks for the ideas you guys r great Jim
Old 06-23-2003, 11:49 PM   #7
Longhorn Man
Like I said...don't quote me on that.
Get it verified first...I'm sure some one on here knows...
Old 06-24-2003, 02:33 AM   #8
Desert Rat
Desert Rat's Avatar
71 and up axels will fit in a 1970 rearend but not a 1969 they are narrower.with a a torch and welder anything will fit,just dont cut and weld in one spot for too long,and warped the axel housings.get your pinion angle right.
Desert Rat is offline   Reply With Quote
