Old 04-26-2013, 05:08 PM   #1
NoNeck
NoNeck's Avatar
Question Installing Wilwood Proportioning Valve
I want to install the Wilwood Proportioning Valve in the photo below in the stock location beside the Master Cylinder. If I could locate a brake fitting adapter it would make installation a lot easier.
I need an adapter that has a 1/8" - 24 male (goes in the bottom of the valve marked "RO") to a 5/16" female (original rear brake line). This would allow me to use my original brake lines under the proportion valve in the original position. I have searched Summit, Jegs and tried calling Wilwood's Tech line (on hold for 20 minutes, never got through).
I know I could bend up a new line, but there has to be an adapter out there somewhere. Any help would be appreciated.
Thanks, POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 04-26-2013, 05:19 PM   #2
k2rm
k2rm's Avatar
Re: Question Installing Wilwood Proportioning Valve
Look at the last post of this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=558663
k2rm is offline   Reply With Quote
