Old 04-26-2013, 05:17 PM   #1
Calioso
Talking Repeat issue alt wiring
I have been reading ur posts on threads about wiring alt. was wondering if u could help me out I have a 84 gmc c1500 sierra classic but I have a serpentine setup and am using a alt. from a 94 350 sbc the only problem I have is it makes a buzzing noise I have changed it out multiple times and upgraded it to a brand new one instead of remand I know it's a wiring issue. I can send u pics. The alt charges and my gauge registers voltage but I know that buzz means my batteries are draining with the ignition off and it's been proven cause I have had to leave my batteries on the charger when I forget to disconnect them. Well sorry for the book just wanted to give as much back story as I could if u can help me I would really appreciate it thanks.
The Cali Bear
Calioso is offline   Reply With Quote
Old 04-29-2013, 05:21 AM   #2
'82 steppin
'82 steppin's Avatar
Re: Repeat issue alt wiring
How did you rewire it? Using adapter connection or just slice the old one? I had problems before in my '92 Z28 and it turned out a wrong wire connected to the pigtail my alt used to be hot as soon as I start the engine
'82 steppin is offline   Reply With Quote
Old 04-30-2013, 12:59 AM   #3
Calioso
I just spliced it in and yea I notice it gets hot at the splice where it feeds to charge the batteries but only when the air bags kick on.
Old 04-30-2013, 12:07 PM   #4
mrolds88
Cali, go over to the 67-72 forum. look up a member Vettevet. He has a write up on this very thing. I believe you need a resistor in there on one of the wires.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
