Old 04-26-2013, 11:08 PM   #1
ShinyC10
cam!!
Anyone know of a good cam for a stock 350 motor? I want a little lope but not to much. I www looking at the 268h comp cam. Any other better cams for this motor??
ShinyC10 is offline   Reply With Quote
Old 04-27-2013, 07:38 AM   #2
b454rat
Re: cam!!
I had that cam in a 350 and worked good. Been over ten years, but I think it had a nice sounding idle...
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 04-27-2013, 10:01 AM   #3
meatwagon83
meatwagon83's Avatar
Re: cam!!
go for it, thats a good cam
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-27-2013, 10:15 AM   #4
Rufton
Re: cam!!
When cam grind is aggressive there is an increased chance lifter tick can be heard. Using lifter w/ proper pump/bleed rate becomes more critical. I would google cam your considering to see if there are ticking complaints. Maybe you can hear example on youtube.
Rufton is offline   Reply With Quote
Old 04-27-2013, 10:41 AM   #5
Rufton
Re: cam!!
Old 04-27-2013, 02:26 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: cam!!
What's the specs on your engine? Stock?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-27-2013, 02:41 PM   #7
ShinyC10
Re: cam!!
It's a stock GM crate motor. 290 hp. Not sure the exact specs
Old 04-27-2013, 05:36 PM   #8
INSIDIOUS '86
Re: cam!!
More often then not the 262 cam from comp outperforms thier popular 268 cam. Sometimes a good grind is just that good. Now the lunati voodoo series was design by udharold who did all the famous ultradyne grinds. Bullet cams has all the masters now and I belive he's working with them. So a lunati voodo 268 cam should run better than completion cams lethargic 268 grind
