Old 04-27-2013, 09:04 AM   #1
Lou Boffa
Lou Boffa's Avatar
Removing inst. cluster bezel?
Question. I'm replacing the instrument cluster bezel on my '70--how does the light switch knob/rod come off?
Lou Boffa is offline   Reply With Quote
Old 04-27-2013, 09:09 AM   #2
DaHos
DaHos's Avatar
Re: Removing inst. cluster bezel?
There is a little button on the switch that needs to be pushed in when pulling the knob out, If you have a tiny head you might be able to see it from under the dash, otherwise its all by feel......
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 04-27-2013, 09:11 AM   #3
Mister-B
Yes. You have to remove it, or the bezel won't come out. Pull the knob all the way out, as you would when the headlights are on. Then, reach your hand up behind the cluster, and you will feel the back side of where the headlight knob plugs in. Up on top of that housing is a button. Push it in and pull the knob the rest if the way off while pushing the button. It's sort of hard to explain. You might want to do a search. There are pictures and other instructions you're going to need
Mister-B is offline   Reply With Quote
Old 04-27-2013, 09:13 AM   #4
cabman420
cabman420's Avatar
Just ran into the same thing when I replaced my headlight switch ,There is a little button on the headlight switch you have to reach under the dash and press and hold it in and the headlight rod should pull right out
cabman420 is offline   Reply With Quote
Old 04-27-2013, 10:49 AM   #5
kcsa75
kcsa75's Avatar
When I did mine, I just pulled and the knob came off. I figured I was in trouble because now it would come off every time I used the light, but I put it back on and haven't had any problem.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-28-2013, 07:02 AM   #6
Square_78
Square_78's Avatar
Be sure to disconnect your battery first otherwise the headlights can't be turned off until you reinstall the knob back in.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
