Old 04-27-2013, 02:48 PM   #1
1bad396ss
Core support mounts 68 vs 72
I have all 68 components going on a 72 frame. The radiator core support mounts on the 68 frame have a smaller opening than the 72.
I ordered new mounts/bushings for 67-68.
Will these work on the 72 frame? Do I need to order 72 mounts/bushings or swap the frame perches? I hope the bushings are core specific and will work with the 72 frame and larger openings on the perches.
Any help or info is appreciated.
1bad396ss is offline   Reply With Quote
Old 04-27-2013, 04:57 PM   #2
Sammy
Re: Core support mounts 68 vs 72
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=38
Core supports bushings should be the only difference. Take a look at the LMC online catalog and check the part numbers and year group divisions. 67-68, 69-72
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-27-2013, 05:12 PM   #3
john
member #16
john's Avatar
core supports are the same on bottom. You need the mounts for the year of frame you use.
john is offline   Reply With Quote
