Old 04-27-2013, 06:43 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Fuel pump loud
So I took the truck back out on the road for the first time this year today, and all went well, tho I did notice some noise from the fuel pump at one point.
My fuel setup used to be a 255 and earls filter, and has always seemed fine. At this point it was a combination of -8 and -6 coming to some 3/8 hard lime.
Just this year, I switched the -6 out for -8 from tank to hard line, and changed out the fuel pump bracket to sit about 3/4" higher and be a bit more out of site.
On the drive, we heard a loud mechanical wine, much harsher than the usual "fish tank" motor sound the pump usually makes. The pump was not hot to the touch, and the noise only changed slightly when revving or idling. We checked our tank, which was about 1/2 full, maybe a tad less.
We drove to the nearest gas station about 1.5 miles away, and when we pulled in, the noise had gone completely back to normal (no fuel added yet).
Put more gas in it, just to have a fresh tank, and have heard to noise since...
So what do you think? A fluke one the first run, or maybe just some air in the line....or something more nefarious? I'd hate to think the fuel pump was dying already. The pump is a few inches above the sump, but it's worked fine and I was told by the rep' that the draw was not too much for the pump. Hmmmm
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-28-2013, 12:33 AM   #2
Kim57
Kim57's Avatar
Re: Fuel pump loud
This is just me thinking out loud but liquid likes to find level. If the pump was above the level in the tank I would think it has to work harder to pull the fuel up and then push it forward. Once you filled up the fuel was probably above the pump so it didn't have to work as hard. Have no idea why it got quiet before the fill up though.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-29-2013, 12:39 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel pump loud
That was my initial though, but I've run essentially the same setup for over a year and 6-8k miles without a hiccup. When I was choosing my pump I found a large question and answer list from a Walborough rep on a rally car build; the said that their pumps could handle about 6-10" of vertical lead and up to about 24" of run before the pump (max).
I took it out again last night and did a 20 minute cross town run in the cooler weather, no signs of extra noise and the performance seems fine.
Old 04-29-2013, 11:02 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Fuel pump loud
With a Walbro 255, it's just a matter of time until it pukes. They are junk.
A few years ago mine got real loud, and it would barely idle at a stop light. Done. Only had 2-3 years on it.
Went to a Bosch 044 and never looked back.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-29-2013, 12:45 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel pump loud
Was there something about your setup that put strain on it (i.e. a little bit of a rise like I have), or did it just kinda die?
I guess my concern would be, would the same thing happen with another (read, more expensive) pump?
Old 04-29-2013, 01:49 PM   #6
Wasted Income
Boosted Member
Re: Fuel pump loud
Strain?....other than the fact it was feeding ~500 rwhp thru a -6 feed line? lol.
It was frame rail mounted, that's about all I can think of.
HOWEVER, the Bosch I replaced it with was feeding the same engine, thru the same fuel system, and mounted in the same location and lived quite a bit longer.
Mine is not an isolated case...I know a handful of guys with swaps around me who've had Walbro's bite it.
Turbo diesel
Old 04-29-2013, 02:58 PM   #7
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Fuel pump loud
good thread here, if you dont mind the fact that its in a miata, and the language.
look at the size differance
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 04-29-2013, 03:05 PM   #8
Wasted Income
Boosted Member
Re: Fuel pump loud
LOL, I've never met a miata guy with a mouth like that....wait...wut?
He's right though...the 044 is a bad mo-fo, but it is quite a bit louder than the Walbro. I think it's even louder than my Fuelab pump, lol
Turbo diesel
Old 04-29-2013, 07:01 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel pump loud
Do you have a pic of how/where your is mounted in relation to the sump/pickup?
For reference, mine looks to be about 7.5" above the sump, I might be able to jack the tank up 2 or so inches if it comes to that.
Old 04-30-2013, 08:34 AM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Fuel pump loud
BR3wCity,
Sorry to hear your troubles, here is what I have, I have a Pierburg pump and I dont think it is loud at all. I hear it when I first turn the key, then nothing. although I only have a stock motor basically, this will drive a 500HP motor.
Good luck brother
http://www.turnkeyenginesupply.com/c...l-System-Kits/
yes it is expensive, but your truck is worth it!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-30-2013, 10:11 AM   #11
Wasted Income
Boosted Member
Re: Fuel pump loud
My Walbro/Bosch were at a similar height in relation to the tank (in the frame rail).
My fuelab is mounted to the side of my fuel tank. I don't have a measurement, but you can get a feel for it in these pics.
Turbo diesel
Old 04-30-2013, 03:18 PM   #12
ChevyCruizer
17's too small
Re: Fuel pump loud
I like the height of WastedIncome's pump in his pictures above. Just figure the lower the better, without having it ripped off my those pesky reflective lane dividers, in my case at least. LOL
Mine is still coming together but I took the standard rear mounted aluminum tank that is usually mounted to the bottom frame rail and set the tank down on the top, raising it several inches. Still have to run the fuel system but I will try and keep the pump as low as possible.
Old 04-30-2013, 07:36 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel pump loud
Thanks guys. Its been good the past few days on small cruises, tho I'm still over 1/2 tank of gas, we'll see if it comes back when it gets a bit lower.
I might be able to switch out a couple fittings and put my pump directly off a 90* on the sump, pointing the pump vertical, but putting the lowest point about even with the sump.
