Old 04-27-2013, 07:21 PM   #1
TwoSmoke
Lowering a 4wd?
Has anyone successfully lowered a 4x4 square? I don't need it to lay frame but wanted to keep it some what low. I need 4wd but don't want a truck that sits up to high.
Thanks in advance
Oh the truck is 84 crew cab dually
TwoSmoke is offline   Reply With Quote
Old 04-27-2013, 07:58 PM   #2
LONGHAIR
Re: Lowering a 4wd?
Being a dually may give you some room for lowering, but part of the height is the taller frame......which you can do nothing about.
There isn't much room for lowering the suspension either because of the space between the oil pan and the front axle housing.
You might get a couple of inches out of it, but not a lot.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-27-2013, 08:46 PM   #3
dieseldawg142
dieseldawg142's Avatar
Re: Lowering a 4wd?
4x4 lower???...
dieseldawg142 is offline   Reply With Quote
Old 04-27-2013, 10:17 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Lowering a 4wd?
I've though about this myself. To get a somewhat low 4x4 truck you would have to raise the engine alot and get the driveshafts sized right. Then try a body drop or such if you want it low like a 5-7 drop. I wanted to do this someday with a beefy turbo small block and a beefy drivetrain to make a sleeper truck that can out launch a dragster haha almost I guess.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-27-2013, 10:25 PM   #5
Ziegelsteinfaust
Re: Lowering a 4wd?
I think he wants his 4x4 maybe 2-3 inches lower like a level 2wd truck. So he can get in, and out of his truck easier.
The OP lives in Alaska, and from what I know it does get a couple inches of snow there every now + then.
I am not a 4x4 guy, but wouldn't a flip kit with lift shackles get you close.
Or maybe a bit of de-arching the springs.
Beyond that your into frame mods.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-27-2013, 11:46 PM   #6
INSIDIOUS '86
Re: Lowering a 4wd?
Raising the spring hangers two inches per side should do it
Old 04-28-2013, 03:38 AM   #7
76C10Stepside
76C10Stepside's Avatar
Re: Lowering a 4wd?
What's the "right" way to de-arch leaf springs (safely)? One guy said he put a LOT of weight on the springs. Sounds dangerous! I assume you have to pull the leafs and do them one at a time in a really big press? Is this better than removing a leaf?
76C10Stepside is offline   Reply With Quote
Old 04-28-2013, 03:41 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Lowering a 4wd?
Always wanted an eldorado front clip 4x4 or a '88 up front clip low and IRS In on shot
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-28-2013, 07:47 AM   #9
b454rat
Re: Lowering a 4wd?
Couple ways to lower a 4wd. Local spring builder did this to his truck.
1. De-arch the springs. Need to take them out, take them to a spring shop. They should have a machine there kinda like an English wheel that will flatten them out correctly.
2. Move the rear spring hangers up in the frame like mentioned. But this will only work on the rear, front are as short as they can go. You could take 2wd spring hangers and put them on.
3. Take springs out of the pack. Again this will only work on the rear, might have 3 springs on the front. Rears have like 9-12 in them, but in doing this, if you haul heavy stuff or tow heavy, it will affect it's carrying/hauling capacity.
4. Smaller tires. Prolby the cheapest and easiest, but will also be the "goofiest". These trucks have too small a tire anyways, and could affect highway speeds.
If you have a hard time getting in and out, I suggest nerf bards or side steps. I have these on my truck, and it does make it easier to get in/out.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-28-2013, 09:24 AM   #10
Rubble
Re: Lowering a 4wd?
Like others have posted,the rear can be dropped fairly easy.It's the front that doesn't have much room to work with.Years ago on my old 80 I dropped it in a rat run & the front diff came up & wacked the starter.This was factory,but sagged springs.If your not getting off road much it might be ok.I would do like b454rat & put on some side steps instead,lots easier & probably cheaper too...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-28-2013, 01:11 PM   #11
TwoSmoke
Re: Lowering a 4wd?
I just wanted to keep it a modest height since the truck will have a sled deck on it and just the ease of not having a lifted truck that will be hauling.
Thanks for the inputs.
Old 04-28-2013, 03:35 PM   #12
cory d
cory d's Avatar
Re: Lowering a 4wd?
seams reasonable to me. 2" lower all around would be neat
cory d is offline   Reply With Quote
