Old 04-27-2013, 11:54 PM   #1
playinsafe44
Power Steering Problem
My power steering was squealing when turning, and it started to get harder and harder to turn when it was at slow speeds (already had checked the fluid, and put a new belt on it). I thought I could fix this with a power steering pump seal kit, and I took it apart, cleaned it, and put it together with new seals. The problem is that when I went to start it, it doesn't feel like I have any power steering at all now. I jacked up the front-end, and went lock-to-lock with the engine cold and reservoir full, and then started it up and went lock-to-lock some more. The only thing I can see happening is fluid coming out the cap area. I don't know what it could be now. Any suggestions?
playinsafe44 is offline   Reply With Quote
Old 04-28-2013, 12:31 AM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: Power Steering Problem
after you put new seals in did you make sure to put the plunger and spring in in the right order? pump is probly on its way out though (if it hasnt given up already..)
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
