Master Cylinder
My Master Cylinder has a leak, and I want to maybe upgrade it when my truck goes down for head gaskets in 2 weeks.
I have a 74 C20, and I have the good old cast iron 2 hole. Does the aluminum from the later trucks bolt-on easy enough? Maybe with just a slight trim to the push rod. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Master Cylinder
Anyone?
Re: Master Cylinder
Power or Manual?
Re: Master Cylinder
Power brakes.
Re: Master Cylinder
The later aluminum master will bolt in but unless you have 11" rear drums you should not use one.
There is no advantage to them over cast iron units. Most c20 have 13" rear drums. Yopu could bolt one in though ![]()
