Old 04-28-2013, 08:47 AM   #1
GMtrucknut!!
GMtrucknut!!'s Avatar
Smile Mustang II ride height ....
I am using a TCI mustang II type front suspension in my 55 2nd series and was needing to look at others stance with stock height spindles. I want my truck lower than original but not slammed as even the paved roads in my area in a slammed truck would wreak havoc on a really low truck. I have cut 1/2 half a coil off and with the stock height but would like to see one that is lower .
GMtrucknut!! is offline   Reply With Quote
Old 04-28-2013, 02:33 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Mustang II ride height ....
I took this pic at the Temecula Rod Run. It has a mustang 2 and sits pretty high.
Kabwe is offline   Reply With Quote
Old 04-28-2013, 06:31 PM   #3
GMtrucknut!!
Thanks Bam ! I don't believe my stance is as high as that , but it isn't slammed either.
Old 04-29-2013, 05:23 PM   #4
Highsider
Highsider's Avatar
Highsider is offline   Reply With Quote
Old 04-29-2013, 08:14 PM   #5
GMtrucknut!!
What spindles are you using on your frontend Highsider ?
Old 04-29-2013, 08:32 PM   #6
_Ogre
_Ogre's Avatar
fatman mustII, standard spindles, full coils, 5.5'' at the rockers
a cut coil or drop spindles would hit the road on mine
i suggest you not drop it any more until you have it done and on the road
shop air compressor timer
Old 04-29-2013, 08:36 PM   #7
Highsider
Highsider's Avatar
What Ogre said!
We are about the same on the front and he is a bit lower on the rear than mine.
