04-28-2013, 10:16 AM | #1 |
Panhard bar question
I'm planning on doing a 4" static drop on the rear of my '72 using drop springs. I know I don't need to notch the frame. What I don't know is can I re-use the OEM panhard bar or do I need to get another one that is adjustable? Thanks
04-28-2013, 10:51 AM | #2 |
Re: Panhard bar question
Doing a 4" drop you will be fine, most agree after 5" or more then you will need an adjustable trac bar and shock mount relocators.
Weev- Life's tough...... It's even tougher when your stupid - John Wayne Last edited by weever82; 04-28-2013 at 12:38 PM. |
04-28-2013, 11:09 AM | #3 |
04-28-2013, 11:18 AM | #4 |
you rear end will b off center using the stock panhard bar// the way to tell is to use a tapemeasure to see the truth
never heard of spring mount relocaters either// guy must b confused with shocks
04-28-2013, 11:46 AM | #5 |
I suspected he was referring to the shock mounts and gave him the benefit of the doubt. But, now I'm confused about my original question on the panhard bar. Do I need an adjustable bar?
04-28-2013, 11:47 AM | #6 |
It really doesn't matter to me if I need an adjustable bar or need to relocate the shock mounts . . . . I just want to do the installation ONCE!
04-28-2013, 11:48 AM | #7 | |
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
04-28-2013, 12:06 PM | #8 |
Moderator
You will most likely need an adjustable bar to re-center the rear end.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-28-2013, 12:14 PM | #9 |
OK, I'm gonna go with the adjustable bar and NOT relocate the shock mounts. Yes?
04-28-2013, 12:15 PM | #10 |
Moderator
You should also relocate the shocks. They are angled pretty steep from the factory and dropping it 4 inches increases that angle.
04-28-2013, 12:50 PM | #11 |
Alllllllll righty then . . . . . . 1 adjustable panhard bar and 2 relocated shock mounts. The shock mounts are riveted in, so the next question is, does the new shock mounts used the old rivet holes or is it a welded in mount?
04-28-2013, 12:53 PM | #12 |
Moderator
They use the same holes. You will need to remove the rivets (lots of fun!).
04-28-2013, 05:28 PM | #13 |
If you only want to do it once then do it right with an adjustable bar and shock relocaters.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
04-28-2013, 05:31 PM | #14 |
just grind the heads off with a flap disk and drive em out with a punch. They are pretty easy to take out if you can get to em...
04-28-2013, 05:43 PM | #15 |
I've got the frame stripped bare and s'blasted so now is the time to get things right. Any recommendations for the best source for the relocated shock mounts?
04-28-2013, 06:39 PM | #16 |
Early Classics Adj bar and relocation kit. Get the one with the 4 lowered shocks. I think about $320 for everything you need shipped.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-28-2013, 06:51 PM | #17 |
I used the CPP deluxe bent adjustable panhard bar, because I have a BIG aluminum diff cover that a regular panhard bar would not clear. And I used the ECE shock relocator kit that I got from a great member on here (Thanks Chad...CC69Rat)!
Picture is before I finished the shock relocator install |
04-28-2013, 07:14 PM | #18 |
My kit
04-28-2013, 07:59 PM | #19 |
I also rave on the ECE shock relocators and adj pan hard bar. Mine installed pretty easy and pure quality!
04-28-2013, 08:00 PM | #20 |
Also it's just easier to cut off the u bolts instead of a gallon of PB and a breaker bar for an hour (don't ask me how I know, lol).
04-28-2013, 09:11 PM | #21 | |
2WD Jimmy
Good quality stuff. Also, that longer adjustable track bar will work much nicer over bumps, no bump steer. Posted via Mobile Device |
04-28-2013, 10:03 PM | #22 |
Your best bet will be to spend the $80 to get a nice adjustable panhard. Most likely you will have a little offset anyways. You can use a tape measure (as said before) but I measure with wheels on to measure easy. You can go from underneath with at full drop and measure the gap between the top of the wheels and the bed side.
