Old 04-28-2013, 03:19 PM   #1
Thiessen1960
1960 C10 rear end swap
So as I am swapping in a front end from a 1979 chevy truck, I want to swap the rear end. I have a rear end out of a 1971 chevy truck, my only question is what panhard bar do I get? And will it just mate up to the original mounting place on the frame? I know they are different from the newer models and was not sure.
Last edited by Thiessen1960; 04-28-2013 at 03:32 PM. Reason: printed something wrong
Thiessen1960 is offline   Reply With Quote
Old 04-28-2013, 03:32 PM   #2
Thiessen1960
Re: 1960 C10 rear end swap
Sorry it is actually the rear Panhard bar that I am looking for to perform this swap correctly.
Old 04-28-2013, 09:47 PM   #3
64swb
64swb's Avatar
Cut the original panhard mout bracket off your original rear (note locatioin) and weld it on the 71 rear. Bolt up the original panhard... done.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 04-28-2013, 11:16 PM   #4
Thiessen1960
The newer rear end has a mounting location for the panhard bar and I'm not much for welding.
Old 04-29-2013, 12:05 AM   #5
Thiessen1960
I just need to know what bar I can buy that will mount up.
Old 04-29-2013, 06:59 AM   #6
bonehead
bonehead's Avatar
Check... that is the way I did mine as well back in the day. Worked perfect.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-30-2013, 02:31 AM   #7
LVPhotos
LVPhotos's Avatar
Same here welded old mount to new rear. The longer the bar the better. You could go to the short mount on the rearend and just measure eye to eye.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-30-2013, 06:07 AM   #8
Thiessen1960
Thanks everyone. I had a friend weld the mount on the new rear end and it bolted in perfectly.
Old 04-30-2013, 07:10 PM   #9
slepysal
slepysal's Avatar
Good to hear any pics of it ? How did the u bolt saddles come out?
I was going to recomend a bolt on bar but looks like you solved it !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-30-2013, 07:18 PM   #10
Thiessen1960
No I don't have any pictures of it. The new rear end still had the saddles on it already. I just had to mount the panhard bar setup.
Old 07-17-2013, 03:43 PM   #11
slepysal
slepysal's Avatar
Big favor could you snap a picture of it installed ?
