Old 04-28-2013, 05:02 PM   #1
Jmageee902004
1964 axle swap
The drive train on my rig is a 64 chevy k10 and the front hubs are shot and replacement ones are not available. So im looking for a newer dana 44 to swap in its place. Not only for the disk brakes but also so i can get parts easier.
Is their a later axle that is about the same length (shorter wouldnt be too big of an issue) that would be a direct swap under my truck? The welder i have isnt good enough to weld on new leaf spring perches. so im hoping thier is an axle with the same perch widths and would just be a simple ubolt swap.
pictures on my photobucket
http://s1045.photobucket.com/user/ma...?sort=3&page=1
Jmageee902004 is offline   Reply With Quote
Old 05-01-2013, 10:05 AM   #2
Dsuper5
Dsuper5's Avatar
Re: 1964 axle swap
Hi Jmagee
I have a 1964 K10 Suburban, i replaced my original axles with 3/4 ton stuff. so the original dana 44 is up for grabs. It has 80k mi on it and worked fine, it has the selectro hubs.
Reason for swap was to be able to stop the thing, disc brakes and power steering upgrade,
lots of work but worth the effort in my book.
Let me know if its worth the effort to ship the ting, my Zip is 86040 Page AZ
Dsuper5 is offline   Reply With Quote
Old 06-21-2013, 11:22 AM   #3
Jmageee902004
Re: 1964 axle swap
hey im still interested in the hubs if your willing to take them off. Also do you have any info on your swap? what year axle and what you had to do to make it work?
Old 06-22-2013, 09:51 AM   #4
'63GENIII
'63GENIII's Avatar
Re: 1964 axle swap
The 44 in the front of mine came from a '73. No fitment issues. It's a 3/4 ton which is still a 44. I like it for the bigger disc brakes.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-22-2013, 06:16 PM   #5
Jmageee902004
Re: 1964 axle swap
interesting so it was pretty much a bolt in swap?
Old 06-22-2013, 11:30 PM   #6
'63GENIII
'63GENIII's Avatar
Re: 1964 axle swap
Yup. Only issue was brake lines for me. Got em through summit with a little trial and error
Chris
'63 k15 long step
