Old 04-28-2013, 06:55 PM   #1
rusty76
rusty76's Avatar
power to manual steering
I did do a search and well not the info I was looking for. At the moment my ole truck has power steering. It's been fine but now I'm getting ready for a tear down I need some info. I know that to go from power steering to manual I need the box and pitman arm. But what else do I need? Are the boxes same length and mount the same? Any variations in the center link? Also will the stock splines on the column to rag joint to box work? I've seen some companies list the boxes as having different splines than that of the power steering boxes. Any help greatly appreciated. Thanks.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-28-2013, 10:09 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: power to manual steering
Just cut the belt and run a resivior for lubrication. These boxes are easy enough to turn as is. Done mine like such for 4 yrs.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-28-2013, 10:34 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Manual boxes are out there.
Just have to look.
Mine was bolt in.
The manual intermediate shaft from power box different
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-28-2013, 11:44 PM   #4
lilpoindexter
lilpoindexter's Avatar
I went to power from manual in my 78 C10. I used the corresponding pitman arms, but the boxes bolted up to the frame the same. The linkage is all the same. I really hated parking that old beast without power steering. I don't remember if the rag joint was different, but I don't think it was.
lilpoindexter is offline   Reply With Quote
Old 04-28-2013, 11:51 PM   #5
cory d
cory d's Avatar
i looped the lines on my box. i dont even have the power steering pump on it anymore. i have strong arms from riding bmx bikes but my cousin drove it just fine. once he realized he cant turn the wheel when the truck isnt rolling
cory d is offline   Reply With Quote
Old 04-29-2013, 06:33 AM   #6
rusty76
rusty76's Avatar
Just have to look.
Mine was bolt in.
What do you mean by manual intermediate shaft is different from the power boxes? Thanks for the help folks.
My build thread
Crossmembers CC
Old 04-29-2013, 12:22 PM   #7
SSC's76
No No
SSC's76's Avatar
Depends on what you get the shafts should be the same. I'm fairly certain the pitman arms are interchangeable as well. The only time I've ran into an issue going the opposite route of course is with a rear steer system in the older cars. You can use either box but if using a power box or manual box made for front steer linkage the pitman arms are different diameter
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 04-29-2013, 12:43 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
The output shaft is smaller by a good bit on the manual box
http://www.google.com/custom?domains...D%3A1%3B&hl=en
Old 04-29-2013, 04:01 PM   #9
rusty76
rusty76's Avatar
Thanks fellas. I kinda thought that they weren't completely interchangeable but close. Thanks again.
My build thread
Crossmembers CC
