04-28-2013, 09:19 PM | #1 |
DIY Tubular A-Arms... Tubing sizes and Cross Arm Suggestions?
I'm getting ready to build a set of A-arms for my '66 C10 with a stock crossmember. I'm wanting to move the wheel forward 1", add more castor by raking the ball joint locations, and make a dropped bag pocket so I can shim the bags with 1/8" and 1/4" plates to change the bag height/pressure without changing the ride height. That way I can fine-tune the spring rate easily. I'll be autocrossing the truck eventually so I'd like the added adjustability over A-arms that are available, and I want to try building them myself for the fun of it.
I've been searching and it looks like 1.25"x.190 wall is pretty standard for the bottom arms, and 1.0"x.190" for the upper arms, but wanted to double check before I bought tubing. I'll be using DOM mild steel tubing. I can't find anyone that sells cross arms, upper or lower that would be suitable for DIY arms that mount to the stock crossmember. Any suggestions? The ball joint cups and upper B/J mount plates are fairly standard so I think I can get those from Speedway. I've pulled measurments from my stock arms to go by, but can't get started making jigs until I have the cross shafts and ball joint plates and cups. I have 4"x4" 1/8 wall tubing to build the jigs.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-28-2013, 10:01 PM | #2 |
Re: DIY Tubular A-Arms... Tubing sizes and Cross Arm Suggestions?
why not using the stock lowers? on some new bushings..
for the top.. i dunno.. you could make a new cross shaft that can take some heims so you can adjust it easy
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
04-28-2013, 10:24 PM | #3 |
Most tubular a-arms I have seen use the stock shaft or billet versions of. I am not looking really so there is tons I know I am missing.
I would get another scrap pair of shafts, and assemble them with wooden dowels for mock up bushings. They bolt them to some angle iron that approximates the mounting to the cross member. The use another piece of doweling to hold the ball joint cup in its position. The only thing I would do different would be to Z the frame for the 1" forward movement rather then make A-arms to do it. That way it keeps your steering shaft in a better orientation. Unless you plan a rack, and pinion then your modding away anyways. |
05-01-2013, 01:51 PM | #4 |
I was trying to figure out how the stock '66 lower cross arms could be used with new bushings and sleeves... they're much different than the '73 up cross arms. I hadn't thought to check the later style.
This is the style I need then, 73 up. I can have delrin bushings and matching steel sleeves made to work with this type arm.
