Old 04-29-2013, 11:51 AM   #1
draggin49
where to hook up chain for cherry picker
Im pulling my engine /trans out of my 69 c10 and painting the engine compartment.
Borrowed a friends picker and it has a chain. Where do I want to hook up the chain too? Do I need one of those plates that bolt to the intake? It has the stock intake/carb so not sure if the plate would work on that.or can I run the chain through bolts in particular areas.
Thanks guys
draggin49 is offline   Reply With Quote
Old 04-29-2013, 12:05 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: where to hook up chain for cherry picker
The lift plates are the cats ass. You can even make your own out of 3/8" plate steel. Make sure you use grade 8 bolts if you use one. If you're pulling the engine and tranny as one unit, using a plate makes it really easy to tilt to make removal a breeze.
You can also use the holes in the front and rear of the heads.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-29-2013, 12:16 PM   #3
cdowns
cdowns's Avatar
i use a chain going diagonal accross the exhaust ports of the heads has worked good for me on v8 engines the past 50years or so
Old 04-29-2013, 01:06 PM   #4
bowtiebubba
bowtiebubba's Avatar
I go diagonal to the accessory holes closest to intake so the chain doesn't damage the valve covers.
bowtiebubba is offline   Reply With Quote
Old 04-29-2013, 01:20 PM   #5
MARKDTN
You may still have the factory lift brackets on the intake. Just run a chain through them and yank that sucker out.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-29-2013, 01:32 PM   #6
bruceman1968
bruceman1968's Avatar
I use the diagonal chain method also. Be careful how you position the chain because during removal...Shift Happens
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 04-29-2013, 01:53 PM   #7
Dale99
x2.
I would think the center pivot would be easier for wiggling and tilting. But it can be done with a diagonal chain.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 04-29-2013, 02:07 PM   #8
draggin49
I figure ill be doing this with various projects so a lift plate for ease of use is a good investment. Found one at autozone for $13, says universal application
Should I assume that this should work with my factory intake that had a 2 barrel on it?
Dont want to drive to go get it if it wont, heres a picture
Old 04-29-2013, 02:16 PM   #9
chevy72blu
chevy72blu's Avatar
I've never used one on a 2 bbl, but they do work well with cast iron intakes. Still, I prefer to use grade 8 bolts in the heads (diagonal) because I usually have aluminum intakes and dont trust the threads.
This one claims to work on a 2 bbl and looks like nearly the same bolt holes. You could always drill your autozone plate out, as well.
http://www.jegs.com/i/JEGS/555/80044/10002/-1
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-29-2013, 02:26 PM   #10
draggin49
Yeah , it looks almost identical .im guessing the closest holes are for a 2 barrel. Good point, ill make sure to go the other route on motors with an aluminum intake in place
Haha maybe I should pickup a creeper while im at the auto part store. Lmao , my 1950's wood snap on one with the swivel wheels is killing me!!
Old 04-29-2013, 02:33 PM   #11
vegadesign
vegadesign's Avatar
ive been doin it for years, diagnal from front side of head and backside of the other
make the back chain shorter to comp for the weight of the tranny
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-29-2013, 07:36 PM   #12
MidLifer
MidLifer's Avatar
Not to hijack the thread but you mentioned creepers - my Harbor Freight plastic one is comfortable as heck, the wheels roll well on asphalt, and it sure was cheap!
MidLifer is offline   Reply With Quote
Old 04-29-2013, 07:57 PM   #13
Rufton
I used angle iron last time and really liked it.
Multiple attachment points came in handy when listing side to side to shoot mounts.
Rufton is offline   Reply With Quote
Old 04-29-2013, 08:36 PM   #14
draggin49
That was creative to use the angle iron.thanks for the tip on the creeper.theres a harbor freight 30min away.ill grab a creeper from there, my back will be thankful!!
Old 04-29-2013, 08:37 PM   #15
draggin49
Grabbed some bolts too
Old 05-03-2013, 01:47 AM   #16
draggin49
Damn...gonna have to drill holes in the plate.does NOT work with the factory intake that had a 2 barrel.
Old 05-03-2013, 09:47 AM   #17
bollybib
bollybib's Avatar
Anyone know of anyone having problems using a lift plate on an aluminum intake manifold ??
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
