Old 04-29-2013, 05:09 PM   #1
biohazardbill
Battery Terminal cleanup
I have a few power feeds that need to run to the positive battery terminal, ie fan relays, air compressor, alternator etc, there are a couple I am leaving out....
Anyway simple solution is to bundle them together and put them all in the battery terminal but that looks a bit ridiculous. My 67 has a 1 post distribution block but that is alot of wires to crimp down on one connector. and will again look a bit ridiculous....
So what have you guys come up with that looks tasteful/hidden? I have looked into some of the car audio distribution blocks but the wires they support are alot bigger than the 10-18 gauge wires I would be connecting.
biohazardbill is offline   Reply With Quote
Old 04-30-2013, 04:13 AM   #2
Square_78
Square_78's Avatar
Re: Battery Terminal cleanup
Go to your auto parts store and see what they have. Check my build thread for what I used on mine. They were cheap too. They have studs on them for larger gauge ring terminals.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 04-30-2013, 05:21 AM   #3
biohazardbill
That battery terminal is sweet. What auto parts store is that from. Do you know the brand or part number for them?
