Old 04-29-2013, 05:52 PM   #1
BlackBettyGMC
FUEL CAP---Help!!
I have a 1972 GMC with the 402bb. I am in need of the correct fuel cap that is vented.....Unless I'm doing something wrong. I bought a couple from LMC but my tank still has a great deal of pressure build up, not good. Does anyone have or know where I can get an NOS cap that is correct?
Thanks,
James
BlackBettyGMC is offline   Reply With Quote
Old 04-29-2013, 07:19 PM   #2
cdowns
cdowns's Avatar
Re: FUEL CAP---Help!!
72 the correct from the factory cap is non vented
the problem is probally // the vent line from the gastank that went up into the passenger side door frame then down into the frame and foward to the charcoal canister to carb// guys disconnect and just plug the lines causing a pressurized tank
if they had common sence and just left the vent line you would have no problem
Old 04-29-2013, 07:57 PM   #3
SS Tim
SS Tim's Avatar
If you are having an ongoing problem it does sound like the vent system itself is having a problem.
As you did not tell us what you actually have, 72 GMC covers a lot of metal and variations we are assuming you have a C1500.
Here are the drawings for a 72 chevy which are directly applicable to your truck if it is a C1500.
They are found in the factory service manual section 8.
If you don't have one they can be downloaded here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Remember if you are having a vent problem or smelling fuel it is most likely in the vent system and needs repairs or correction from a hack job improvement.
SS Tim is offline   Reply With Quote
