What differential do I have
Hello all,
I have a mistery on my hands that no one seems to be able to solve. So, I thought I'd try here. I appreciate any info. Thanks The Truck: 1963 GMC C1000 Differential cover: 10 Bolt (3 inches from bottom bolt to next bolt in line) Gear Ratio: 3.90:1 Ring gear dia: around 9" (little rough measuring with a tape measure) Last edited by Mr_B; 04-29-2013 at 06:43 PM. Reason: mispelling |
Re: What differential do I have
Top right hand side of axle housing will have series of letters / numbers, that will tell us what it is......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Rear diff cover looks like a Dana 35 rear end. Thats what our 61 has in it.
Glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
eaton h032
Ok, does anyone know if the square plug
Can be removed to fill/check the rear did Gear oil? Posted via Mobile Device
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes that rear plug is where you fill the differential with gear oil. The bottom of the fill hole is the proper level. And I agree with j.kirn, that is an Eaton HO32 differential.
Thanks Capt Fab. Looking his pics I see some differences. Ours has studs with nuts to hold the cover on. His has botls. Thanks for the info on the plug to fill the level. I have tried removing our plug with no luck. Its most likely been on since 61.
Glenn
Thanks a bunch. I now have a good idea where my options are.
Posted via Mobile Device |
| Bookmarks |
