Old 04-29-2013, 07:56 PM   #1
sir_talk_alot
sir_talk_alot's Avatar
Ok to run wheel adapters?
So i got a killer deal on some incubus 18" wheels. I bought them to resell because they are 6x5 for blazers. Then curiousity got me to see about adapters. Roadkill enterprizes makes a set of adapters that are $250 for all four. They are billet aluminum 6061-t6. I was wanting to find out who has used spacer adapters before and is there a hp/tq limit? Im going to have a built small block at 400hp.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 04-29-2013, 08:31 PM   #2
69GWC
Re: Ok to run wheel adapters?
I have them on my 69, mine are 1" wide and I used to to get my offset right where I wanted it.
I dont have anywhere close to 400hp but it runs out real good and will lite the tires up and have not had any problems yet.
I also have ran them on my 4 wheeler for years and never had one come loose or break.
69GWC is offline   Reply With Quote
Old 04-29-2013, 08:32 PM   #3
69GWC
Duplicate.
Old 04-29-2013, 08:40 PM   #4
tmc1986
i think you'll be ok. i ran them on my toyota. i didnt have a lot of HP but i did really low gears and lockers front and back. i abused the crap out of that thing and never had any issues. maybe stay away from the real cheap ones unless you know they are good quality
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 04-29-2013, 09:19 PM   #5
sir_talk_alot
The wheels are 18x8.5. From what i measured it has a 5.75 backspacing +25 offset. What size spacer should i run to avoid rubbing and not stick out of the fender well. They make 1.3" 1.8" 2"
-Mike-
Old 04-29-2013, 09:25 PM   #6
buckskins4ever
buckskins4ever's Avatar
I used a set on mine before buying my Ridlers. They were only on the truck for about 150 miles worth of driving. I still have them and if interested.....I will sell for $175 shipped. PM me if interested and I can get with you on how to buy.
buckskins4ever is offline   Reply With Quote
Old 04-29-2013, 10:25 PM   #7
sir_talk_alot
Who makes the adapters? Are they solid billet aluminum?
-Mike-
Old 04-30-2013, 01:30 PM   #8
Wowcars
You can get cast aluminum or billet. Trust me when I say STAY AWAY FROM THE CAST ONES! I used a couple on my caprice wagon years ago and there was enough flex in them they ended up taking out the hub bearing and race. Never again.
Wowcars is offline   Reply With Quote
Old 04-30-2013, 02:37 PM   #9
tommys72
tommys72's Avatar
I had a set on my bagged s10 for 5 or 6 years, never had a problem at all, 18 inch rims
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 04-30-2013, 02:37 PM   #10
sir_talk_alot
Well these are billet cnc machined specifically for my application
-Mike-
