Old 04-29-2013, 07:58 PM   #1
dropanddrag71
dropanddrag71's Avatar
running bad, please help!
70 Chevy, SBC, automatic...
When I start it it runs nice, today it started bucking and bearly ran after 30 minutes or so.
Stuck on the side of the road, I hadda turn the idal screw all the way just to keep it from stalling to make it home. Once home I turn it off, restart it and it,s screaming the ideal is so high, I lower it and it goes from running nice to bucking, to running nice again. It has a clear fuel filter and it's full.
6 months ago it was the same thing, shop installed a new Msd streetfire, did a rewire, correctly and now it's back. All I can think of is a bad fuel pump or Carb.... any ideas?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
Old 04-29-2013, 08:19 PM   #2
SS Tim
SS Tim's Avatar
Re: running bad, please help!
Did you check for a vacuum leak?
SS Tim is offline   Reply With Quote
Old 04-29-2013, 08:25 PM   #3
dropanddrag71
Re: running bad, please help! MANUAL CHOKE??
I did look around, but isn't there a method of spraying a fluid on the lines and it will either speed up or stall?
**** I should mention that my truck has a manual choke and there IS NO cable attached to the Carb... wondering if the choke can be moving cause there no cable holding it n place...
Old 04-29-2013, 08:52 PM   #4
MidLifer
MidLifer's Avatar
If you spray Brakleen around vacuum fittings and lines, and you have a leak, it should speed the idle up temporarily. Carb cleaner will also work iirc.
MidLifer is offline   Reply With Quote
Old 04-29-2013, 09:04 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
If you have a manual choke you have to make sure it stays open. We used a piece of coat hanger to hold the one open on my '67, it was easy to do and is not noticable.
Check all the rubber hoses in the fuel line. There is one on the suction side of the fuel pump and one under the cab. The one on the suction side of the fuel pump was collapsing on one of my trucks. The sock on the suction of the fuel line in the tank was collapsing and causing problems on another truck.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-29-2013, 09:16 PM   #6
dropanddrag71
If it was a bad line or sock, would the clear fuel filter be empty? It's full now and always
Can the choke open and close while driving with no cable attached to it
Old 04-30-2013, 12:23 AM   #7
1972_Buford
Fuel sock maybe? clogging the line?
1972_Buford is offline   Reply With Quote
Old 04-30-2013, 03:25 PM   #8
SS Tim
SS Tim's Avatar
Have you diagnosed a fuel delivery problem or just changing parts and hoping your drivability problem goes away?
Old 04-30-2013, 03:46 PM   #9
don t. - 72gmc
When it dies, check for spark at a plug.
HTH...don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 04-30-2013, 05:03 PM   #10
dropanddrag71
I am no machanic, so I am trieing to solve this...
Today I got up and noticed the air cleaner was dirty, changed it, also found a spark plug was very, very loose, redid that, then undid the gas cap some, allowing it to vent better.
Drove fine all day, bit I still don't trust it yet more then a few miles from home
Old 04-30-2013, 05:17 PM   #11
cdowns
cdowns's Avatar
does this have a ponts distributor? cleaning points and setting the gap or dwell is good to do
cleaning and gapping the sparkplugs is good to do
changing the fuel filter inside the carb inlet is a good thing to do
if this has been sitting for any length of time a gas cleaner in the gastank is good//i like berrymans gas treatment available pretty cheap at walmart some guys like seafoam
a service manual is good for peeps of all ages
Old 04-30-2013, 06:17 PM   #12
ole dollor
ole dollor's Avatar
is your motor a v-8 with a four bbl carb, some times the back butterflies will hang open and that will make one run real bad, check your carb and make sure they close all the way. you should be able to spray down in the carb and spray on the outside and clean it up, flop the back butterflies open sever times and do this with the motor OFF. let it set a few minutes and crank her up and see how she runs...good luck on the truck.
ole dollor is offline   Reply With Quote
Old 04-30-2013, 07:06 PM   #13
dropanddrag71
6 months ago I had a shop install a Msd street fire, wires, plugs etc.
Sitting?... this truck got a full restore in 2000, sat in his garage till summer 2012. I came along and I,m driving it and dealing with sitting issues
Old 04-30-2013, 08:58 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
When the shop installed the HEI did they bypass the 12v "resistor" wire that was originally used on the points distributor?
The HEI needs a constant full 12v... not 12v with a resistor.
Also if it's the stock 40 year old Q-jet... it could need a throttle shaft rebush to prevent a wicked vacuum leak.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
