04-29-2013, 09:24 PM | #1 |
Spacer size help
I got a deal today on a set of 6lug wheels that are 6x5 off a trailblazer for 275 with tires. He bought the truck and didnt think his daughter needed flashy rims.
The wheels are 18x8.5. From what i measured it has a 5.75 backspacing and using a chart came to +25 offset. What size adapter/spacer should i run to avoid rubbing and not stick out of the fender well. They make 1.3" 1.8" 2". Roadkill enterprizes makes a solid adapter from 6x5.5 to 6.5. I have a full drum truck. Thanks Posted via Mobile Device
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
04-30-2013, 05:23 PM | #2 |
67-72 parts collector,…
Re: Spacer size help
I would mock them up under the truck,... and place them where YOU like how they look.
Then just measure from the wheel to the drum. The back wheels will need a wider spacer.
