Old 04-29-2013, 10:19 PM   #1
fredm98
Active Member
Boss 338 - 20x8.5 on 1.25 Rotors - No Mods
I got a set of these 20x8.5 Boss 338 with the full expectations of machining down the rotor. But to my wonderful surprise, they bolted right on, no spacers, no grinding, no turning down, perfect fit. These are the style with the O-ring cap. The rotors are off a 1976 1/2 ton. 255-40-20 front and 285-40-20 rear on 20x8.5 wheels all the way around.
fredm98 is offline   Reply With Quote
Old 04-29-2013, 10:21 PM   #2
fredm98
Active Member
Re: Boss 338 - 20x8.5 on 1.25 Rotors - No Mods
more pics
Old 04-29-2013, 10:22 PM   #3
bugmasta
bugmasta's Avatar
Sweet! My wheels will be here tomorrow so I am hoping for the same luck. I am fully prepared to grind but if I don't have to, AWESOME!
fingers crossed........
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 04-30-2013, 05:22 PM   #4
fastnotch89
fastnotch89's Avatar
The 20's with stock rotors and spindles you will need a spacer, on the 22's like i have, all i had to do is knock the dush cover in just alittle.
fastnotch89 is offline   Reply With Quote
Old 04-30-2013, 10:58 PM   #5
bugmasta
bugmasta's Avatar
Wheels came and I had to grind down the rotors. No big deal. I have factory 72 rotors on the front so not surprised. Tires show up tomorrow so new shoes will be rolling tomorrow afternoon.
Old 05-01-2013, 10:23 AM   #6
ulakovic22
Good looking truck, what are the specs on the drop?
ulakovic22 is offline   Reply With Quote
Old 05-01-2013, 12:12 PM   #7
Codez67Chevy
Codez67Chevy's Avatar
Nice Mitutoyo's lol and wheels.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 05-02-2013, 07:59 PM   #8
fredm98
Active Member
Well I'd estimate it a 4-6 maybe 4.5-6.5? I cut a half turn from the springs and have 2-1/2 drop spindles. The rear springs are junkyard find out of a late model full size chevy car. How do you calculate the drop? Maybe measure from the centerline of the wheel to the top of the wheel arch? What are those measurements from the factory?
Old 05-02-2013, 08:01 PM   #9
fredm98
Active Member
bummer you had to grind. Must be the 73-79 rotors are thinner. Post up some pics once you get her all rollin'
Old 05-03-2013, 08:56 AM   #10
bugmasta
bugmasta's Avatar
up and rollin! had to add 1.25 spacers to the rear as well even with a 72 rearend.
