04-29-2013, 10:41 PM | #1 |
DND Trucks
Petronix ignition issues
Anyone ever install the Petronix ignitor 3 on our trucks? My app is a 71 BB, mostly stock.There's a resistor wire somewhere that causing a voltage drop to the coil between 6-9 volts during start up. The ignitor needs a constant 12 volts to work properly. Anyone run into this before? LMK, thanks Dave.
04-29-2013, 10:58 PM | #2 | |
The Older Generation
Re: Petronix ignition issues
LockDoc
04-29-2013, 11:59 PM | #3 |
Msgt USAF Ret
The resistor wire you are talking about comes from the firewall block and runs to the stock ignition coil where it joins a yellow wire from the starter R terminal. The yellow wire gives the coil a full 12 volts during startup and then the resistor wire feeds the coil with reduced voltage during normal running.
You have a couple of options here. You can run a new wire from the fuse panel on the ign unfused terminal like Doc says or you can remove the resistor wire from the firewall block and run a wire from there to the pertronix unit. Here's a picture of the resistor wire, It's the cloth covered one and it was orange purple and white from the factory. Here is a diagram of the stock resistor wire shown by the red arrows.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-30-2013, 07:48 AM | #4 |
DND Trucks
Wow, thanks guys, I appreciate the info! I checked my wiring and I don't have the resistor wire described, however, I will be running a seperate wire from ign unfused. I'll take some pics tonight.
Vet, where did you get a color schematic? Thanks again Dave. Posted via Mobile Device |
04-30-2013, 08:18 AM | #5 |
The electrical diagrams are available in the Thread/Thread Starter area of the electrical forum. http://67-72chevytrucks.com/vboard/s...d.php?t=185856 LockDoc
04-30-2013, 09:18 AM | #6 |
Check the Petronics instrucktion sheet. Some of them use the resistance in the circuit. Mine does.
04-30-2013, 11:55 AM | #7 |
Msgt USAF Ret
Be careful of the coil too. I bought a shiny chrome blaster coil but it was 3.8 ohms resistance which is made for the six cylinders and the v-8s use the 1.8 ohm coil. I don't know what the difference is but they said it won't work with the v-8.
It must be in the resistance value and using a ballast resistor.
04-30-2013, 12:40 PM | #8 | |||
"I ain't nobody, dork."
The MSD Pro Billet HEI I have in my rig now needs a 12v constant. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
