04-29-2013, 11:45 PM | #1 |
ideal mounting points for upper a-arms
Ok I was thinking about possibly changing my upper a- arm inner mount locations. I am running tubular uppers and my alignment is good. A guess would be to lower them a little since tall ball joints are not available.
Instead of being level like the lowers they are of course are set at different heights. has any analysis been done to determine if a different height is better. Just thinking as I read about the suspensions. Posted via Mobile Device
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-01-2013, 12:03 PM | #2 |
Re: ideal mounting points for upper a-arms
I am going to look at some of the available software to see if I can model the front suspension and see if it shows any benefits to changing these upper locations. Since we all lower these trucks and sometimes add wider shorter tires I know there is room for change. I am sure the performance cross members available have made appropriate changes I cant spend the money of a pre built system so I was hoping to correct some of this using some stock and aftermarket parts.
