Old 04-30-2013, 12:36 AM   #1
jackandkoke
window regulator problem
Hard to explain without someone actually seein it. Window keeps jumping track. Putting in new regulator cause the old one was bad anyways. If u lay it flat crankside down should the rollers that attach to the windo itself be the same heighth or is one higher?
jackandkoke is offline   Reply With Quote
Old 04-30-2013, 10:30 AM   #2
Desert1957
Desert1957's Avatar
Re: window regulator problem
I'm not quite sure what your asking, But both rollers go into the window glass track. Only one goes into the door piece.
Desert
Desert1957 is offline   Reply With Quote
