Old 04-30-2013, 07:47 AM   #1
Codez67Chevy
Codez67Chevy's Avatar
Cutting Coils
So I'm sure there is a bunch of you guys out there that have cut your coils to drop your trucks.
My questions are will my ride still be the same?
Will my rear coils be too soft to haul anything?
So I'm planning on a 3/4 drop, I know I'll need shock relocator brackets and drop shocks. So how is it I go through this?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 04-30-2013, 08:00 AM   #2
sir_talk_alot
sir_talk_alot's Avatar
Re: Cutting Coils
You cant cut the rears. And the fronts will stiffen alot. I did it to the front and its definately alot stiff up front.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 04-30-2013, 08:11 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cutting Coils
I'm surprised to hear this. I wouldn't think that cutting a coil would affect the spring rate at all. Do you have any idea why it made it stiffer? Are the "A" arms hitting the bump stops?
Thanks for any info you can provide on this.
LockDoc
Leon
Old 04-30-2013, 08:19 AM   #4
CC69Rat
CC69Rat's Avatar
Re: Cutting Coils
I have never understood why it would make the spring stiffer either. Not saying it wouldn't.. just saying I dont get how cutting say half a coil with a cutoff wheel makes the spring rate stiffer. Can someone explain the scientific reason why?
Subscribed..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-30-2013, 09:55 AM   #5
sir_talk_alot
Re: Cutting Coils
I cut 1 and a quarter coil for a 2.5 in drop. a coil spring is a torsion bar wound in a circle. a 300 PPI spring with 10 turns should gain 30# if you cut off 1 full turn. this is not true with progressive wound springs
-Mike-
Old 04-30-2013, 09:59 AM   #6
sir_talk_alot
Re: Cutting Coils
Look at it like a diving board. Got a 6foot board and 200lbs bouncing at the end there is plenty of spring in the board. Cut off 3ft and then Go bounce on it and see how much springiness you get. Thats the easiest way for me to explain
-Mike-
Old 04-30-2013, 10:05 AM   #7
Justin36
Justin36's Avatar
Re: Cutting Coils
Lol that was a great reference!
Justin
Justin36 is offline   Reply With Quote
Old 04-30-2013, 11:53 AM   #8
Codez67Chevy
Re: Cutting Coils
So why can't you cut the rears?
Members I've met...
Mister-B
Old 04-30-2013, 11:57 AM   #9
Codez67Chevy
Re: Cutting Coils
So why can't you cut the rears? And would I just be better off buying a drop kit?
Members I've met...
Mister-B
Old 04-30-2013, 12:00 PM   #10
Custom 68
Custom 68's Avatar
Re: Cutting Coils
because the rears bolt in place. They have a pig tail if you will call it that on the top and bottom. Yes you will need new springs for those.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-30-2013, 12:35 PM   #11
sir_talk_alot
Re: Cutting Coils
Easiest thing is do the research on here about cutting coils and buy drop coils for the rear
-Mike-
Old 04-30-2013, 01:05 PM   #12
CC69Rat
CC69Rat's Avatar
Re: Cutting Coils
Ok, makes sense.. . Thanks
Chad
Old 04-30-2013, 06:37 PM   #13
Square_78
Square_78's Avatar
Re: Cutting Coils
A coil spring is a lever. Shorten the lever and it makes the work harder to do. Shorten a coil and it feels stiffer. It won't be that bad though. You won't need drop shocks or relocators for 4" drop. You will bottom out on your bump stops long before your shocks bottom out. My 78 is lowered 5" up front with cut coils and it rides fine. I almost want to switch to some 3/4 ton coils to stiffen it up more. I wouldn't recommend cutting them that much tho. You can get a 3" drop by cutting 1.5 coils and you will be fine. Just get an alignment afterwards.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 04-30-2013, 07:38 PM   #14
JOJABOY
Re: Cutting Coils
Now your sounding like a Theoretical Physicist. (BAZINGA!)
JOJABOY is offline   Reply With Quote
Old 04-30-2013, 08:21 PM   #15
ecgate
ecgate's Avatar
Re: Cutting Coils
You can heat your rear coils up and the rear will drop. I used to have a truck with cut coils in front and the guy heated up the coils in back for a drop and I've never had a rougher riding vehicle. If you want good ride quality I would buy a drop kit. If your on a budget you can lower your truck at minimal cost but your ride quality wont be near as good. lolife would be able to point you in the right direction.
ecgate is offline   Reply With Quote
Old 04-30-2013, 08:23 PM   #16
sir_talk_alot
Re: Cutting Coils
If your budget go to a local 4x4 shop amd ask for some old jeep tj rear springs. They gave me a pair. They will give you a 4-5 in drop. They are soft so cant haul much unless you get monroe adjustable airshocks for $80.
-Mike-
Old 04-30-2013, 09:01 PM   #17
68corvair
Smile Re: Cutting Coils
Just finished up cutting one round off my front coils. Also added a frt sway bar from a c20 camper special. Put 4inch drop springs in the rear. I had previously put gas shocks on the front, air shocks on the rear.
Man,what a huge difference in ride and handling !! Drives great ! Tightened up the ride,got rid of that floating feeling, best 125 bucks I have spent on this truck.
Ended up with a nice 2/4 drop too !
Cutting springs ,when done in moderation,works great!
Ed in S.C.
71 cheyenne
68corvair is offline   Reply With Quote
Old 04-30-2013, 09:30 PM   #18
JOJABOY
Re: Cutting Coils
Ed in S.C.
71 cheyenne
$125 for all that? Or just for rear coils?
Old 04-30-2013, 09:59 PM   #19
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Cutting Coils
Hubscrubs wifes truck has/had rear cut coils you CAN cut the rears..
John
1999 Toyota Tacoma 4x4
Old 04-30-2013, 10:07 PM   #20
68corvair
Cool Re: Cutting Coils
100.00 for the springs,25 for sway bar w/bushings/brackets.
( shocks have been on it for a year already )
Ed
Old 04-30-2013, 10:11 PM   #21
JOJABOY
Re: Cutting Coils
I have leafs in back of mine so haven't done much yet. I did put a 1 1/4" swaybar in front. Was thininking of a 1 coil cut in front and 2" shackles in rear and remove bottom (short) leaf for a 2 1/2" drop.
Old 04-30-2013, 10:32 PM   #22
sir_talk_alot
Re: Cutting Coils
Technically you could do anythng. Yea you could cut your rear coils and only bolt it on ine side but thats about as smart and safe as duct taping basketballs instead if coils from your frame to trailing arms. It would be wise to shop around for rear drop coils. You can find them for 80-90. Summitracing,cpp, ebay. Or if you dont want to haul stuff jeep springs.
-Mike-
Old 05-01-2013, 01:24 AM   #23
rattle69
rattle69's Avatar
Re: Cutting Coils
I work at a shop that lifts newer jeeps everyday and we just toss the springs. It's funny reading this because I was looking at a pair in the scrap bin thinking that they might fit on a c10. Any idea what kind of drop if any the 07 up rear jeep springs would give? How about other vehicles stock springs? Maby an 80's regal or cutlass, el camino?
70 lwb c-10
rattle69 is offline   Reply With Quote
Old 05-01-2013, 05:20 AM   #24
sir_talk_alot
Re: Cutting Coils
Search the forum there are lots of jeep springs threads. I believe there is a guy who used chevelle springs. Im fixing to try out a set of jk springs which i think are a bit stiffer.
-Mike-
Old 05-01-2013, 10:06 AM   #25
67chevemall
67chevemall's Avatar
Re: Cutting Coils
I would put bags in the rear and cut the fronts until you can afford to bag the front then finish the job.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
