![]() Join Date: Jan 2003
Parting out 1972 Blazer
Picked up this for the top and Windshield frame / Cowl. The body is pretty shot, Frame has some good parts and the bed sides are salvagable. Has big block manifolds
PM or call / text 703-906-3344 |
![]() Join Date: Dec 2004
Re: Parting out 1972 Blazer
any chance you have the shifter bolt for the transfercase
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
No, that wasnt there
Interested in the lower body trim, Does the pass side have it also?
![]() Join Date: Apr 2010
so was there a big block in there? If so how much for the engine crossmember?What you doing with the roof rack any more pics?
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
Boosted Member
How is the rear bumper and gravel guards?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Carpe manana
![]() ![]() Join Date: Dec 2010
Any under-dash lights near the kick panels or an under dash speaker?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
Looking for the gas tank skid plate and the rubber floor leveling mat.
Thanks, Tbruz |
![]() Join Date: Jun 2011
Any interior rear panel stands?
Posted via Mobile Device |
![]() Join Date: Jan 2002
Does it have the radio speaker and cover that hangs under the dash any rear carpit strips.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
Visors, seat belts, seats????
Are you going to cut up body if so interesred in both taillight sections cut up past side marker lights
#13 |
I need the both of last 5 or 6 inches of the frame horns in the rear on each side. Could you post a picture of that? Shipping to 74701?
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
#14 |
Drivers side rocker box end cap?
#15 |
Drivers side door regulator, and actuator?
#16 |
![]() Join Date: Oct 2012
Interested in the rear most cross member and the front spring hanger for the driver's side rear spring if you are parting the frame.
Jeff Posted via Mobile Device |
#17 |
![]() Join Date: Feb 2010
hows the roof rack?
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
#18 |
Fuel tank fill pipe? Right side bed side panel?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#19 |
68 panel: Attached a pic of the other side trim. Its there but not perfect.
2003 Silverado: Im not sure on the diffences in the big block mounts, so here is a closer pic Wasted: Im using the rear bumper for mine Deadhead: Lights are not there Tbruz: Neither are there Maddox: Im using those in mine Gary 70: Neither are there Leroy: Visors are there, no seat belts hvac: I would consider that 72blazer: I will get a pic next time 1972: those are not there botmfedr: drivers door was already gone Blazertime: Those are there. I will be parting the frame 72K5zl1: The roof rack is there,and complete, but one the way back the rear air deflect came loose and bent one of the rails. I think it could be bent back and used though. jjzepplin: No Fill pipe (but I might not use the one on my Jimmy), and did you want the whole panel ? |
#20 |
Are you cutting up body if so I am interested in the taillight sections cut up past side marker lights both sides and what about dash is it available
#21 |
Please send pics when you get the body off and price shipped to 66085.
Thanks.. Jeff Posted via Mobile Device |
#22 |
I will be cutting up the body. I need some parts of the winsheld frame and cowl. im not using any of the dash.
#23 |
I could use the dash at least the centr section mine had a CD player put in and was hacked also could I get pics and price of the visors?
#24 |
Looks like woodgrain? Mine has black moldings.
#25 |
Let me know a price if you decide to cut up sides and dash also would be interested in pieces that you bolt top to or bed rails and dash and I am in nc could possibly meet you
| Bookmarks |
