Old 04-30-2013, 11:58 AM   #1
Matty Wagz
Matty Wagz's Avatar
1971 steering/brakes/etc in a 1966 NEED HELP!!
NEED some help... I corrected the mistake I made on the upper A arms; now I am thinking I have the center link in backwards (flipped) also...
comparing to the original 66 center link, i have it in wrong.
can anyone look and let me know ASAP...???
check out my build thread... elbow deep in my 66
thanks in advance,
WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC
Matty Wagz is offline   Reply With Quote
Old 04-30-2013, 12:10 PM   #2
Reyals Bemus
Re: 1971 steering/brakes/etc in a 1966 NEED HELP!!
I think you've somehow managed to attach the center link upside down. All the holes are tapered, so I'm not sure how that happened...
Reyals Bemus is offline   Reply With Quote
Old 04-30-2013, 12:14 PM   #3
Matty Wagz
Matty Wagz's Avatar
I don't have anything tightened up yet, just finger tightened; tried racking steering from side to side and noticed I had an issue; 1st was I had the upper A arms in on wrong sides; fixed that and still had issue w/ drivers side tie rod hitting nut on bottom of pitman arm...
think I will trying to flip and see what happens....
thanks for the info.
Will follow up with what I found.
thanks,
WAGZ
Old 04-30-2013, 12:17 PM   #4
tincan1966
tincan1966's Avatar
Like Reyals said- all the holes are tapered, would be kind hard to install upside down, but that is how it looks.
tincan1966 is offline   Reply With Quote
Old 04-30-2013, 12:50 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: 1971 steering/brakes/etc in a 1966 NEED HELP!!
Not the best views, but hope these pics will help.
Sam
>> http://www.classictrucks.com/tech/12.../photo_06.html <<
luvbowties is offline   Reply With Quote
Old 04-30-2013, 12:54 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
It's backwards!
The inner tie rods connect on the BACK SIDE of the center link.
(inner tie rod nuts will be on the front side)
Keith
Convert to disc brakes.
Old 04-30-2013, 02:06 PM   #7
Matty Wagz
Matty Wagz's Avatar
OK, so if I am reading this correctly and looking at the pictures right, the center link is installed correct per the tapers and not clearing the cross member...
I just need to move the tie rods around to the inside of the center link..??..
Let me know,
Thanks,
WAGZ
Old 04-30-2013, 02:12 PM   #8
Reyals Bemus
Just pull the centerlink off and have a look at which ways the tapered holes are directed, and install accordingly.
Old 04-30-2013, 02:34 PM   #9
DURG
DURG's Avatar
And take that socket off too!
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 04-30-2013, 02:39 PM   #10
Matty Wagz
Matty Wagz's Avatar
YOU GUYS ARE THE BEST!!!!!!!!!!!!!!!!!!!
This looks a little more like it is supposed to...
No clearance issues now!
Thanks to everyone's help; moving right along now.
WAGZ
Old 04-30-2013, 02:39 PM   #11
Reyals Bemus
Yes sir - you got it now!
