Old 06-23-2003, 12:58 PM   #1
chevy1969
402 BB or 402 SB?
I have a friend that has a 402 BB motor just setting around that was given to him, he told me it was out of a 1970 chevy....I was a little confused when he said it was a BB, I thought that the 402's came as a SB......
Can anybody shed some light on this subject for me?
One more question, Did'nt chevy have the emblem on the fender that read 400, but it is actually a 402?
Any help with what is what on these motors would be great!!
Life is short, so play hard!!
chevy1969 is offline   Reply With Quote
Old 06-23-2003, 01:02 PM   #2
70c10
67-72 Addict!
70c10's Avatar
I always thought it was a 396 BB that they called a 402. The cars had 400SB I thought. Somebody will correct me if I'm wrong.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-23-2003, 01:02 PM   #3
Smooth68
Smooth68's Avatar
402 is a BB, actually a factory bored 396. There is also a 400 SB
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 06-23-2003, 01:02 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
The 402 is a BB, the 400 is a small block. The 402 is a factory bored over 396, first appearing in 1970 (in 68 and 69, BB trucks had 396's). The 400 badges on a truck indicate the 402 BB was installed, not a 400 small block.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-23-2003, 01:10 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Heres a pic of a mostly stock looking 72 402BB. A 400 SB looks like a 350 for the most part.
Old 06-23-2003, 01:11 PM   #6
chevy1969
So if I'm reading this correct, the 402 is a BB period even if it had a 400 badge on the fender, if it is a SB then it actually is a 400 and not a 402?
One last thing, which one is harder to come by and which one would you guys prefer?
Thanks again for all the info. !!
Old 06-23-2003, 01:17 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
You are correct.
Me, I prefer the BB. The 400 SB has a thin casting from what I've been told and is prone to overheating. You can build the SB cheaper than a BB. I guess it really boils down to what you application is and funds availability.
A lot of people must love the 400SB. I've had 2 and had no trouble selling them for good money
Old 06-23-2003, 01:23 PM   #8
Smooth68
Smooth68's Avatar
I think one of the main things that the 400sb is good for is stroking - ie 383.
Smooth68's Web Site
Old 06-23-2003, 02:00 PM   #9
XXL
Seņor Member
XXL's Avatar
I believe the center bores are siamesed... and thus no room for water jackets through there.
Kenneth
XXL is offline   Reply With Quote
Old 06-23-2003, 02:15 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Yup, that's what I was referring too. Here is more info:
The next major milestone in terms of performance was the introduction in 1970 of the 400cia block. This deviated from the standard format in many respects. First, it used a nominal 4.125in bore, as opposed to the 4.000in bore that had become the norm. To achieve the 4.125in bore, some internal casting core changes were necessary. The most obvious external change was the use of three freeze plugs in the side of the block. To accommodate this larger bore size, the bores were siamesed; there was no water between the cylinder bores because the barrels joined in the water jacket. In contrast, all other blocks have water completely surrounding each cylinder bore. Along with this change in the bore size, the 400 motor was equipped with a 3.750in stroke cast crankshaft. To get this bore & stroke combination within the confines of the standard 9.025in crankshaft center to block deck height it was necessary to shorten rod length if the stock piston ring package was to be retained. The standard 5.70in rod was then shortened to 5.56in.
Old 06-23-2003, 03:58 PM   #11
stllookn
Saving 1 truck at a time!
stllookn's Avatar
The 400 small block can be built out to 468 ci using the Rocket block. They are desireable because the heating problems are vastly overrated and you can get great power without changing everything under the sun...brackets, motor mounts, header size etc. I think those extra cubes come in handy when your are trying to spank your buddies wheezebag 350...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-23-2003, 05:02 PM   #12
chevy1969
You guys are the best!!!!!!!
Thanks a million for all the info.
Old 06-23-2003, 10:38 PM   #13
STP67-72
STP67-72's Avatar
I have always been asked if the 67-72 trucks had 400 smallblocks. I have never heard of it before.
STP67-72 is offline   Reply With Quote
Old 06-23-2003, 10:47 PM   #14
hobby67stepside
I think the SB 400 was introduced about '75 or so.
hobby67stepside is offline   Reply With Quote
Old 06-23-2003, 10:48 PM   #15
lukecp
Formerly yellow72custom
lukecp's Avatar
The 400 SB wasn't an option until sometime after '73.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
