Old 04-30-2013, 05:47 PM   #1
ecgate
ecgate's Avatar
POL's tubular motor mounts????
Anybody use the tubular motor mounts off of the Performanceonline.com. Im having a hard time tracking down the motor mounts for the bbc 68-71 style. I have the stands but I cant find the mounts unless I want to pay out my rear. Anyway Im running a bbc with headers and was wondering if anybody had some experience with this set. Was the motor mounted to far back or forward, any clearance issues with headers, ect.............?
http://www.performanceonline.com/196...RACKETS-16820/
ecgate is offline   Reply With Quote
Old 04-30-2013, 06:04 PM   #2
mgkgmc
mgkgmc's Avatar
Re: POL's tubular motor mounts????
I had just ordered the small block stands and they were very easy to install.
I had ordered them because my headers were hitting the stock stands by switching them to the POL stands it gave more than a inch clearance for my headers. But I was happy how much easier it was to mount the motor to the new POL engine stands but Im not to sure how the big block mounts probably similar. I wish I did it sooner.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 04-30-2013, 07:34 PM   #3
see ten
WTB this ad
see ten's Avatar
Well... they bolt in either the 6 or 8 cyl position... also "offset" somewhat forward... supposedly to allow the use of hei and clear the firewall.
I used them when I swapped to an LS.
see ten is offline   Reply With Quote
Old 09-23-2014, 10:57 AM   #4
joey8383
joey8383's Avatar
Bump
See Ten used these on his LS swap.
Any other info on these being used on an LS swap on 67-72? What exhaust manifolds did you use? Did you use regular adapter plates or sliders? Transmission tunnel low hump or high hump? Thanks for any info!
joey8383 is offline   Reply With Quote
Old 09-26-2014, 05:16 PM   #5
RaceAGMC
RaceAGMC's Avatar
I used the POL tubular mounts, regular plates, low hump tunnel, and I have a 4L80E. I have Doug Thorley swap headers, but I know that TBSS manifolds will fit without any mods.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
