Old 04-30-2013, 06:08 PM   #1
Rnd
Tire and Wheel Size Question
I recently purchased a 1977 GMC C2500 3+3 no duals. It has front disc brakes(factory) and a 14 bolt floating axle with 4:10 ratio. 454 with 400 auto trans.
My question(s) is/are: What bolt pattern does it have? 8x165.1 /8x6.5 or 8x170? or something else.
It has 33/12.5/16.5 on it now with factory wheels. Stock was 9.50/16.5.
I think I would like to put on 275/60R18's or 265/50R20's.
I can't order online without knowing the bolt pattern..
Any thoughts and/or info would be appreciated.
Thank you, Randy
P.S. How about offset?? Is this something I need to be concerned with ?
Rnd is offline   Reply With Quote
Old 04-30-2013, 06:16 PM   #2
b454rat
Re: Tire and Wheel Size Question
8x6.5. The tires you listed are kinda small, is this 2wd or 4wd. By the C in 2500 guessing a 2wd. I have 305/55/20s on my 'Yota, and they are equal to a 33x12.5....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-30-2013, 06:25 PM   #3
Rnd
Yes, it's a 2 wheel drive. The 33 x12.5 seem a bit tall I would like to get around the 31x10.5 range.
I'm having a hard time finding the running diameter of a 9.50 x 16.5 tire.
If I could come up with this it would help me in tire and wheel selection.
Thanks for the input.
Randy
Old 04-30-2013, 07:07 PM   #4
Ziegelsteinfaust
A 265/70/16 is the same size, and offers lots with the E load rating. If your willing to go smaller.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-30-2013, 07:09 PM   #5
b454rat
These trucks came stock with 235/85/16s, which is about a 31-32" tire. The 9.5/16.5 is roughly the same size I think....maybe tad shorter and wider...
If you want a wider tire, but roughly the same height, a 275/70/16 is close. If you want wider, then need a 60 series tire...
Old 04-30-2013, 10:52 PM   #6
MusicMan70
MusicMan70's Avatar
Rnd
I measured 29.5" on the truck.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-01-2013, 12:35 AM   #7
Rnd
Thanks guys that helped.
At this point I think I'm going to get a set of Mickey Thompson Classic 3's. 17x9x8.65 with Pirelli Scorpion STR 265/65/R17
That should be around the stock diameter and slightly wider.
