Old 06-23-2003, 01:22 PM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
quick ? on fuel lines
Can anyone tell me what size the main hard fuel line is? I have an electric fuel pump on my truck and the whole thing has been plumbed with rubber lines. I want to replace at least part of this with a hard line as the hoses are starting to perish but can't find what size it should be. I'm gonna just buy a length of tube and bend it to shape and connect it with short lengths of braided hose to the pump and carb.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-23-2003, 01:27 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
3/8th for V8, 5/16 for I6
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-23-2003, 03:52 PM   #3
tom hand
CCRider
tom hand's Avatar
You could get 8 or 10 mm if that is easier for you
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-23-2003, 05:19 PM   #4
68racer
Yeah baby!
68racer's Avatar
Use Kunifer Copper/Nickel alloy tubing, it is easy to work with, won't rust and won't crack like pure copper. It is available from Frosts Auto Restoration which is very close to you.
Did you get that engine mount in OK?
11.37 @116
68racer is offline   Reply With Quote
Old 06-23-2003, 05:31 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually, the 2bbl V-8 engines had 5/16 also.
Run a 3/8 or whatever that would be in metric...10mm I think.
Good call on dumping the rubber line...not safe at all.
Old 06-24-2003, 01:16 PM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
Neil, got the engine mount on with much swearing and grazing of knuckles, you were right, had to loosen everything up again and line it all up before tightening it up.
I had forgotten about Frosts, I'll have to take a trip over this week. I've got their latest catalgue so I'll have a look in there. I want to get them changed over before I get a leak and a fire!
Phil
'67 C10 long fleet.
